How did this work out for you?I have some Toyo 35x11.5 going on my steelies tomorrow. I’ll report back with pictures.
Did you put the lift on yet?No lift or level. I bought the 2” lift from zone off-road, but have not put it on yet. I kinda like the look without the lift. Drives great and feel more stable with wider wheels.
Not yet. Still up in the air about it. Might wait a little longer and end up doing a true suspension lift.Did you put the lift on yet?
Came out great. Love the look and the ride. Ever so slight rub occasionally when I turn hard right into a parking space, but I need to take it in for alignment.How did this work out for you?
Was the offset the problem? I am wondering if spacers would fix this?Did the exact same to my BD and did not work with the stock steelies with 35x12.5x17. Tires hit the sway bar on full lock. Had to upgrade rims.
2 inch level kit 4wp
17x8 American Racing Baja's 0 offset
Dick Cepek EXP 35x12.5x17
Will be putting on Sasquatch fender flares
any issues with spare tire? I have a non sasquatch Black Diamond and added OEM 35 sasquatch tires and wheels. Did the spare fit?I went with 35x10.5 Kenda's on my BL stock wheels. No issues.
Fits fine, third brake light is a little tight but usable. May change it out in the future.any issues with spare tire? I have a non sasquatch Black Diamond and added OEM 35 sasquatch tires and wheels. Did the spare fit?
ThxsFits fine, third brake light is a little tight but usable. May change it out in the future.
I have a base OBX/2.7/LUX arriving next week and I was able to find a pair of Sasquatch take offs locally for $1000. I'll sell the stock OBX wheels and tires so getting the wider 17" Sasquatch OEM wheels isn't very costly. My dealer has done lots of 315-70R17's on non SAS Broncos with no lift or just a 1" leveling kit which is what I'm doing. Here's a base one with 35's and no lift that I just saw at the dealer an hour ago. He said they were +20 offset but I'm not sure if he really new. I like the stuffed look but it would look great with the 1" leveling kit as well.That is a good point. I guess that is the point of this thread. Just trying to figure out if it Is doable and okay or not.
If not I have an alternative that is a little smaller. Just want to go as big as I can on the stock option.
Any rubbing with this set up??Did the exact same to my BD and did not work with the stock steelies with 35x12.5x17. Tires hit the sway bar on full lock. Had to upgrade rims.
