Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)?
atlbrvefn
Black Diamond Bronco
35x11.5 Toyo ATs with 2” lift
Ford Bronco Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)? F7AC4749-6007-47E7-9665-F1EC175097BB
Hyfly
Hyfly
Idaho
BRONCO
Hyfly
Hyfly
Idaho
BRONCO
No lift or level. I bought the 2” lift from zone off-road, but have not put it on yet. I kinda like the look without the lift. Drives great and feel more stable with wider wheels.
Did you put the lift on yet?
Biltwild
New York
2014 Nissan Titan Pro-4x , 2021 Ford Bronco 4Dr BD
Not yet. Still up in the air about it. Might wait a little longer and end up doing a true suspension lift.
atlbrvefn
How did this work out for you?
Came out great. Love the look and the ride. Ever so slight rub occasionally when I turn hard right into a parking space, but I need to take it in for alignment.
Ford Bronco Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)? CF550E48-9261-4DA5-8565-757648F0F267
sfs1963
South Mississippi
74 Bronco, 23 Bronco, 22 Toyota Camry TRD
Did the exact same to my BD and did not work with the stock steelies with 35x12.5x17. Tires hit the sway bar on full lock. Had to upgrade rims.
2 inch level kit 4wp
17x8 American Racing Baja's 0 offset
Dick Cepek EXP 35x12.5x17
Will be putting on Sasquatch fender flares
Hyfly
Hyfly
Idaho
BRONCO
Ford Bronco Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)? 20220115_145927 (1)
Was the offset the problem? I am wondering if spacers would fix this?
sfs1963
South Mississippi
I believe it was. I am not a fan of spacers and not sure if it would solve the problem.
Drew5150
Drew
1975 International Scout 2
I went with 35x10.5 Kenda's on my BL stock wheels. No issues.
any issues with spare tire? I have a non sasquatch Black Diamond and added OEM 35 sasquatch tires and wheels. Did the spare fit?
Vellicate
James
2018 F150, 2014 Flex Limited
Fits fine, third brake light is a little tight but usable. May change it out in the future.
BaseBD
Wisconsin
2021 4D Black Diamond
I put the 3rd brake light extension on when I went with the Kenda's. The issue I found was the soft top rubs on the brake light bracket when all the way down. Seeing that the tire fits with the brake light in its normal spot, I am going to remove the extension before top down season.
Hyfly
Hyfly
Idaho
BRONCO
It fits...
this is 315/70/17 on stock rims with no lift.
There was a very small amount of rub at full turn.
I have since added a level and new rims.
MnLakeBum
MN and FL
‘18 Range Rover Diesel
That is a good point. I guess that is the point of this thread. Just trying to figure out if it Is doable and okay or not.
If not I have an alternative that is a little smaller. Just want to go as big as I can on the stock option.
I have a base OBX/2.7/LUX arriving next week and I was able to find a pair of Sasquatch take offs locally for $1000. I'll sell the stock OBX wheels and tires so getting the wider 17" Sasquatch OEM wheels isn't very costly. My dealer has done lots of 315-70R17's on non SAS Broncos with no lift or just a 1" leveling kit which is what I'm doing. Here's a base one with 35's and no lift that I just saw at the dealer an hour ago. He said they were +20 offset but I'm not sure if he really new. I like the stuffed look but it would look great with the 1" leveling kit as well.
Ford Bronco Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)? Screen Shot 2022-04-04 at 12.58.00 PM
Ford Bronco Will 315/70/17 tires fit Black Diamond (Non-Sasquatch)? Screen Shot 2022-04-04 at 12.57.20 PM
B Miller
Sherwood, OR
Any rubbing with this set up??
