Will a Sasquatch fit in a garage?
USASAIL
St Petersburg, FL
Volvo S90, Chevy Suburban, Base 2Dr
A standard garage opening is 7' tall. Will a Sasquatch'd Bronco fit inside one? With the standard rack?
Rollerstud98
Christian
Airdrie
2015 Nissan Titan
I think it’s like 79 or so inches with the rack so will be tight but should just clear. Adjust your door to open up high enough and you’re set.
jtzako
Jason
Xterra Pro4x
You'd have 4 or 5 inches of clearance. The sasquatch package height is actually shorter than my current xterra (lifted etc). I only have about a 1 -2 inch clearance currently so the Bronco will be a better fit.
Jook13
Josh
Prescott az
Suzuki samurai
I build custom homes, 99% of the homes we build have 8 ft tall garage doors. Maybe because here in Prescott AZ lifted trucks are so common. But 9 or 10 ft ceiling height is the new norm and an 8ft garage door isn't really much more expensive.
LemonShark
Christian
Wilder, KY
2018 Mercedes C43 AMG, 2018 Honda Odyssey
This thread sent me right to the garage with a tape measure: seven feet. Yaay!
I then measured 6'9" . . . I know the math says it's fine, but that's gonna' "feel" close.
Spooled
Republic of Texas
If it won't fit just deflate the tires and you'll gain a good bit of clearance.
Don't forget to reflate them after taking it back out of the garage
/s
BroncoST
Kevin
U.S.
2 fiesta STs
Man I wish I could put it in the garage but recent events made me turn it into a gym instead. The barbell is the one thing I love more than cars and I ain't ever going without that again. The Bronco would definitely be a tight fit and I have the standard 7ft but it should work according to specs.
Spooled
Republic of Texas
My Wrangler has a 3" lift on 35s and has no problem fitting in the garage. I'm pretty sure a lifted Bronco will fit.
Ford Bronco Will a Sasquatch fit in a garage? 49299053478_40a840bf96_b
I'm impressed you got the raptor to fit in the 3rd car spot in the garage. How close is it?
MVP
Orange County
I have a short garage door at 80” and a short garage ceiling. The specs say a Badlands with a roof rack will be 77.4”.
JesseFSU
Jesse
2021 F150 Hybrid 4x4 Platinum
Oh no...My 4 story work garage is 6'8" and my 2019 F250 4x4 just barely fits, like less than an inch but it fits. Trading my F250 in for the First Edition so it better fit!!!
Sgt Beavis
Rick
2019 Ford Raptor, 2018 Jeep Wrangler Sport S.
It's got about 3" on each side. I've only got 8" total clearance for the length as well. It's not really that hard to park. I use the edge of my driveway to gauge my approach. Then I get my driver side rear tire as close to the garage edge as is reasonable and back straight in. After that I just need to remember to fold the mirrors. So far I haven't forgotten to do that.
At one point I had a Ram crew cab with a long bed. I had to back up, making a 90degree turn, to park it at our old house in Texas. Now THAT took some effort..
Jp215
James
Pennsylvania
2015 F150
I can fit my wife’s expedition and my F150( lifted 2 in with 34in tires) I’m my garage although not at the same time anymore due to added storage but if I can fit either then the bronco shouldn’t be a problem for me
