Wind Noise From Roof Rack - 2 door
mike8675309
Minnesota
This weekend I was cleaning up the garage, which meant getting that best top bimini installed on the bronco.
To do that of course I had to start with removing the roof rack, which no is taking up some room in the garage.
I then had my son come over and help me remove the roof and we installed the bimini and then put the roof back on.
Now the entire time with the roof rack there has been enough wind noise that conversations with my soft-talking mom could be a challenge when going 60mph. I assumed it was the roof rack, and I can say that after removing the roof rack, it was the primary cause of wind noise.
There is still some wind noise but it is dramatically less than when the roof rack was on there. I won't need the roof rack all the time, so I'll keep it off but for when I need it.
Ford Bronco Wind Noise From Roof Rack - 2 door PXL_20220723_210919960.MP
Rat
Larry
WV
22 2dr Bronco Wildtrak, 22 Bronco Sport Badlands
Good to know, I ordered mine with the roof rack as figured it would cost less that way. I will hopefully be getting mine next month. Will see how it sounds and pull it off as well if it is unbearable. I would like to get the twill slide back for the warmer months on there anyways and I dont think that will work with the roof rack.
Deleted member 32220
Guest
God to know indeed, At 60 I start hearing mine. At 65 it’s pretty pronounced. At 70 about the same.
That’s about as fast as I’ve had it.
Your the first to confirm that, I asked another 4 door owner that did the same thing and he said he didn’t really notice it?
Mdsuits
05 f350, 68 bronco 89 samurai
I took mine off and as well…and yes I agree….way quieter without it.
mike8675309
mike8675309
Minnesota
Yeah I finally can hear the road noise from the tires, which isn't bad, I just couldn't hear it compared to the wind.
jasonkosi
Jason
Chilliwack, BC, Canada
Drove mine for 6 months with no roof rack, then put one on. Personally I don’t notice much difference.
DaveInSA
Seguin, Texas
2021 Bronco Badlands 4DR, 2007 Saturn Sky
Yeah... when I first picked up mine I had the roof rack, yakima towers, yakima large platform, and hi-lift mount...
IT WAS LOUD. And massive buffeting noise.
I took off the hi-lift mount from the platform... not much difference.
Removed the platform, huge difference.
Removed the rails, noticeable difference..
Added the pipe insulation... noticeable difference.
Which is kind of a bummer. Can't just leave it all on, will need to put it on and take it off as needed... Or drive with aircraft headphones and an intercom system for my passengers :D
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
Scott R Nelson
Meridian, ID
I took my roof rack off right away and hung it up on the wall in my garage. I didn't have it on long enough to notice any difference in wind noise. The rack goes back on when I need it, then I'll take it off again.
Gilligan
Gilbert
Youngsville NC
My Son told me this trick, wrap some type of parachute cord around the cross bars. Doesn't have to be tight, just about an inch or two apart. It quiet down right much.
