Yes, exactly! The new exhaust is not removing the sound from the wastegate like the stock exhaust did.So is it possible that the more free flowing system could be promoting the wastegate dump creating the “woooosh” sound?
Maybe you should stop reading it then. Just trying to understand if it’s an install problem, a leak at one of the couplings, a muffler configuration issue, or just the way that it is…This is me reading this thread
I was thinking heatshield as well. I've tucked mine up pretty tight and have it angled for even more clearance. It's pretty close.Yup. That’s a pretty good summary of the sound. If you throw on your PSI gauge you will probably notice what I did that when boost gets up around 10psi + it starts. At WOT ya for sure I hear it. And to your point about the “metal” sound I actually thought perhaps I was hearing a metal sound resonating from the factory heat shield reverberated through the tailgate floor to the cabin (I’m still considering this as a possibility).
in a few mins I’m going to try rotating the muffler a little to try to move it a bit further from the heat shield below deck and then test.
If you have already solved it please definitely let me know.
Perhaps Magnaflow will chime in here? Is there a rep on this board? I will be calling them first thing Monday morning if I haven’t sorted it out.
Thank you.I was thinking heatshield as well. I've tucked mine up pretty tight and have it angled for even more clearance. It's pretty close.
Also, the sound was 100 percent not there before. I have a hard time myself buying that it's a wastegate noise that with less restrictions made it to the back.... Considering the cats are still there.... And I put a resonator inline as well that should along with the cats, disrupt and catch any blowoff resonance!
