7MT Driving Habits & Owners Manual
Bronkers
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Right on cue, MEJ gifts us this.
1st place: best graphical representation of my quandary šŸ˜†
Alot of great feedback from the internet here. Consensus: I'm lazy/not trying hard enough. I did previously let the revs die off before going to neutral. But I shall now also rev match and downshift!
Techun
Pa
BD, 2.7, MIC, 4dr
Primary reason for me in the car world tho, is to keep the engine in boost. Taking it out of gear and letting it go down to idle at speed will lower the oil circulation, coolant flow, and drop the boost pressure down to pretty much zero.
Being in gear without a lot of throttle... you're not going to be in boost. And it won't go to zero, it will go negative.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
I did a lot of downshifting while stopping driving a Spitfire, 240z, 911 and Miata, and sort of got away from it moving into sport sedans (VW Jetta, MB 240 and BMW 530), and then really with the JKUR.
The guy with the Audi down the street whoā€™s used to have an STi Subaru does every time he rolls in.
Iā€™ll have to experiment with the JK. Somehow the experience is not as spirited on road, but maybe the Bronco will bring back the spirit!
the poacher
john
Whistler
2010 ford ranger
I have only owned manual transmissions since my first vehicle at 15, and have always downshifted to a stop. Unless of course, it is an emergency stop. Keeping the vehicle in gear keeps you in control, and stops excessive wear on your brakes. I have never had to replace a clutch, but I certainly have had to replace many brakes.
Ricepuddin
Nate
2017 BMW 340i and 1998 bmw m3
In the section about maximizing fuel economy, the driver's manual suggests: "Do not shift into neutral when you are braking or when your vehicle is slowing down"
My questions are:
1) Do they mean this regardless of MT or AT?
2) Is fuel economy affected by this due to the fact the engine is essentially idling? (which as I understand it, is not as much of a fuel-sipping state as it might seem?) Excessive idling is also not great for engines in general but that's another topic.
3) (For experienced manual drivers) *As a general rule* do you downshift when slowing to a stop or do you use brakes only? If you downshift, do you do it sequentially or just pick up 1st gear somewhere near the very end of the slow-down?
In my first 3 vehicles (all manual) and ~10 years of driving, (as a general rule) I did not downshift except when accelerating from cruising speeds. To stop, I just went into neutral and applied the brakes with discretion. I replaced one clutch on the first vehicle which had been used and abused by the previous owner (older sister). Brake job intervals were around 30k miles in all 3 IIRC.
Last question: Am I foolish or just lazy for planning to drive this way when I get my Bronco? (Safety cop nit-picks 'you won't be able to react as fast if you're not in gear,' notwithstanding)
The only real question is are the pedals properly spaced for some good old heel-toe shifting in the corners....
Also why the hell would you shift a automatic to neutral at a stop?
BigFootie
Wisconsin
2013 ES-350, 2022 Badlands Sport, 2023 Heritage Ed
All depends on the situation. Coming off the highway to a light, almost never downshift through every gears, but never coast in neutral or with the clutch in. Coming down a steep hill or slowing in traffic, I always downshift.
actually had to think about the response. Driven a manual my whole life both cars and motorcycles. Really donā€™t pay much attention to it as itā€™s just automatic after 50 years.
I will say, brakes are much easier and less costly to change despite what others might suggest. I still only need to change pads and rotors maybe every 50 or 60k. Havenā€™t had to replace a clutch in 45 years. Wouldnā€™t want to on a transaxle either!
Dads_bronze_bronco
I donā€™t get excessive wear on the brakes - If I was driving an automatic in Drive and coming to a stop the brakes would wear more than a manual disengaged.
AZshot
Desert Southwest
Vintage Motorcycles, F-150, various other
I don't mean semantics or specifics even, but doesn't an automatically pretty much disengage the gears when you lift the throttle? In effect, coasting and letting you use just the brakes. Unless you push a "sport" button or GOAT mode. I'd say that's what I do with a manual, if I choose to use a mode where the gears slow me down, I do. Or I coast and just use the brakes. I just don't push a little button and let the computer decide.
Gcardieri
George
Tucson
Hyundai Santa fe
When the situation or my mood calls for downshifting I downshift. When I want to coast in neutral I do it. If I need to pop it back into gear I can. The point is every driving situation is unique and I have complete control to do exactly what I want the vehicle to do when driving a stick.
AZ_Liberty
2007 Expedition
The only time I am in neutral is idling at the ATM. You should be stopping in 2nd, and shift to first once completely stopped.
I normally get about 40,000 miles on a set of front brakes, 80-120 thousand on the rear.
Lakelife36
Ben
Interior of BC
Wait - MEJ is still a thing? I lost it on FB a while ago when it merged with something else. What platform can I find it on?
Gcardieri
George
Tucson
Hyundai Santa fe
If Iā€™m stopping at a stop sign I do what you suggest, but if Iā€™m gonna be at a traffic light for multiple minutes why would I remain in gear with both legs extended on peddles? Nothing wrong with being in neutral. Even if Iā€™m the first one at the light I can engage from neutral into first gear and get off the line quicker than the guy next to me almost every time.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
With a 95:1 crawl ratio, one thing you don't want to do is coast down a hill off road in C gear with the clutch pedal pushed in. At 20 mph in low range your clutch disc would spin about 17k rpm and could explode and come through the floor! It's happened before so driver beware.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Still FB, idk what else.
AZ_Liberty
2007 Expedition
Both legs? I normally take my foot off the brake once I am stopped. But... Phoenix is pretty damn flat.
