Aguanga
Range Rover
Updated with pics now that I have my Bronco. First big trip this past week towing this unit through the Smoky Mountains. The Bronco kicked ass! No issues towing at all. Sweet spot was 71 mph on the interstate. 2,100 rpms and averaged 14.5 mpg for the entire trip. 4.27 gears. Tongue weight was 420 lbs. fully loaded. Includes the WD hitch and a full propane tank up front.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours C6BD0367-805A-468C-8BB6-351E1489B366
What is the make and model of your trailer? Do you have a rough weight when you're loaded down with water in the tank? It looks like something I may add to my list of contenders... You mentioned a weight distribution hitch, but I haven't seen one like that. Does it move weight from the rear to the front axle of the bronco when it's engaged? Also do you have the Ford or Redarc brake controller? Thanks
bronco_billy
Indy
Crown Vic
Jayco Hummingbird 16MRB is the make and model. They no longer make this model, so you can look for a used unit or check out their new light weights. Refer to the link below for specs. up the specs for this model.
The hitch is made by Anderson. I love this hitch. It has built in sway control built into the ball. A WD hitch moves weight from the rear axel of the Bronco to the trailer axel. Helps to keep the front wheels securely on the ground
I am using a Curt wireless brake controller. No wires or box needed up front. Works by using an app on my phone. Luv it! Links below:
https://andersenhitches.com/product/weight-distribution-hitch/
https://www.curtmfg.com/dm/echo-mobile-brake-controller
https://www.jayco.com/rvs/travel-trailers/2018-hummingbird/16mrb/
Cheers!
Burgler2112
Andrew
2022 Black Diamond Bronco 2.3l Mid Soft Top
This was me last night to pickup a mattress. Installed the hitch and wiring myself, so it was fun to see the payoff.
What wiring harness did you use?
GToddC5
Todd
South Jersey
www.bronco6g.com
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 1667475849193
LightRefined
Randy
Vicksburg, MS
2022 Ford Bronco Outer Banks
NVCowboy
William
Henderson, NV
I suppose a photo of my 6x12 cargo conversion purpose built for a Bronco sitting all alone or hanging off the ass of my Superduty would contain too much sarcasm, generally ruining the feel good nature of this thread.
Gtrekker
Gary
Ford Bronco Broncos Pulling Trailers Pics - Add Yours 20221003_113431
Moto26
Tucson AZ
Gtrekker
Gary
Whose Bronco is that? Cuz it sure as hell ain't yours with all those doors! 😂
🤩🤣🤣 Yeah, it's in the garage waiting for the buyer to pick it up.
Team 2 Door = Purpose Built and Badass 😎
Moto26
Tucson AZ
That trailer certainly looks purpose built and bad ass! It actually makes the Raptor look small…
Gtrekker
Gary
Yeah, it's close. The width is perfect for the Braptor. It's another story for my 2 door... I dont have a side view with the 2 door.
