💡 Budget air: 20 to 40 PSI in 8:20
66GT
Thomas
Tacoma, WA
03 Marauder, 66 Mustang GT, 65 Ranchero, 64 Comet
I intended to build an on-board air set-up using an upfitter switch, but after building this kit, I'm keeping it just like it is.
First I built the deflation set using lock-on tire chucks ($5.99) [x4] and 1/4" ball valves ($4.69) [x4].
That's all you'll need to air down in no time at all. Just open the ball valves and watch your air pressures go down on your display.
The air compressor and hose set-up connects directly into these. I used two of these industrial coupler and plug kits ($19.99 each) [×2]
After looking at comparisons online, the air compressor I used was Smittybilt's S/B2781. Purchased at 4WP for $183.
SPECIFICATIONS
Duty Cycle:40 Minutes @ 40 psi
Maximum Air Pressure:150 PSI.
Amp Draw:36 to 50 Amps
Voltage:12 Volt
5.65 CFM (Cubic foot per minute) air intake
With a duty cycle of 40 min, you won't have to let it rest unless you do multiple vehicles. Actually, one of the reasons I decided to not build it into the Bronco is so I can lend a hand to others that don't have a kit.
The wheelbase of a 2dr needs about a 10 ft hose to connect the rear wheels to the front. For this section, I bought a 25 ft 3/8" hose ($15.99) [x1], cut it in half and added a male threaded end with barb from a repair kit on each end ($2.79) [x4]. This 12.5 ft section would work for a 4dr as well.
The hose has a coupler on the downstream end and a plug on the upstream end.
To connect both the front and rear wheel to the compressor, I used a 1/4" T-fitting ($3.99) [x4] with two couplers and one plug.
For the section from the compressor to the front wheels, I used two T-connectors - one to connect the two 8 ft sections of hose - and the other to add in a 160 PSI gauge ($5.99) [x1], which can be used in multiple configurations.
I cut off the Smittybilt connector and converted it to an industrial coupler to be consistent with the rest of the connectors.
I bolted the compressor into a Pelican case (approx 16×12×6) I already had on hand. This is what it looks like as a complete "kit".
Note: Several of the pics were taken during dry fitting. Make sure you use a good amount of teflon tape on your connections. One of the benefits of using the Merlin red plug and fitting set is that most of the fittings have thread sealant already applied.
This is what it looks like in use. The power connectors go directly to the (+) and (-) battery terminals. The two wheels are connected by the T-connectors.
PERFORMANCE
20 PSI to 40 PSI: 8 min 20 sec
(The first 20 PSI to 30 PSI took 3 min 40 sec.)
I used the original Smittybilt bag for hose and connector storage.
Total cost was $341 ($183 for the compressor and $158 for the hoses and fittings). Add in another $65 for HF's Apache 4800 case, if you want one.
Edit: First time using it on the trail for several hours of wheeling. Super easy.
Svanhildr
Christal
Ford Escape
I intended to build an on-board air set-up, but after building this kit, I'm keeping it just like it is.
Ford Bronco 💡 Budget air: 20 to 40 PSI in 8:20 20220619_204500
SPECIFICATIONS
Voltage:12 Volt
The wheelbase of a 2dr needs about a 10 ft hose to connect the rear wheels to the front. For this section, I bought a 25' 3/8" hose ($15.99) [x1], cut it in half and added a male threaded end with barb from a repair kit on each end ($2.79) [x4]. This 12.5' section would work for a 4dr as well.
The hose has a coupler on one end and a plug on the other.
For the section from the compressor to the front wheels, I used two T-connectors - one to connect the two 8' sections of hose - and the other to add in a gauge ($5.99) [x1], which can be used in multiple configurations.
I bolted the compressor into a Pelican case I already had (approx 16×12×6). This is what it looks like as a complete "kit".
PERFORMANCE
This is great! Thank you for sharing!! 🤩
mikec426
Russellville, AR
22 4dr Sqtch, 20 Triumph Tiger Rally, '04 Yam FZ1
Awesome! I plan on doing something very similar. Already have that compressor from when I had a Jeep a year ago. 😁👍🏼
privateer35
Seattle
Ford Bronco 2021
This is great! Was curious what a budget setup looks like. I think below ten minutes great. Will be buying this this weekend!
DaveInSA
Seguin, Texas
2021 Bronco Badlands 4DR, 2007 Saturn Sky
Just a heads up for anyone interested, that compressor is on Amazon for $169.99 right now.
JakeC
Jake
Dearborn, MI
michiganbroncos.club
2022 Badlands
Could I ask if you might be able to curate a ”total” parts list, with links towards product?
[Great write up, so it’s a big ask, I know. Thanks! ]
MayhemMike
Mercury
Curious what the inflation time is while using the compressor on just one tire. Have you ever timed that application? Thanks, great demo y the way.
mikec426
Russellville, AR
I’ve got a recovery gear bag with enough space leftover that I can store my hoses in. I also had a Pelican case gathering dust in my garage to put the compressor in (I have the same one as the OP).
Got everything from Amazon.
2 sets of Tanya hardware air hose fittings and air coupler plug, air compressor quick-connect FNPT female plug kit (industrial type D, 1/4-inch NPT female thread, solid brass, 2 piece @ $5.99
SUNGATOR 12-pack air hose fittings, 1/4” NPT to 3/8” barb, hose barb adapter with sealant, brass pipe fittings make threaded with hose clamps, 12 pieces. (Only used 8 I think) @ $16.99
Flexzilla Air Hose withColorConnex Industrial Type D Coupler and Plug, 3/8 in. x 50 ft, Heavy Duty, Lightweight, Hybrid, ZillaGreen - HFZ3850YW2-D @ $40.11
WYNNsky Air Splitter, 3-Way Manifold with 3 Pieces Industrial Coupler and Plug, Air Compressor Hose Accessories Quick Connect Fittings @ $18.97
Horiznext 3/8 inch mini 2 way brass barb air ball valve for water gas fuel shut cut off 10mm pex tubing, (2pc in pack) @ $11.99
AstroAI 4 Pack Air Chuck, Heavy Duty Closed Flow Lock On Tire Chuck with Clip for Inflator Gauge Compressor Accessories @ $22.99
Da by 2 pcs 3/8"(10mm) Brass Tee Barb Fittings for 3/8" ID Hose,6 pcs Stainless Steel Pipe Clamps,3 Way Union Intersection for Water/Fuel/Air(T) @ $7.99
2 of Milton (S-715) 1/4" FNPT Female M-Style KWIK-CHANGE Coupler @ $5.99
MEASUREMAN 4-1/2" Dial Size, 304 Stainless Steel Case,Drinking Water Lead-Free Contractor Pressure Gauge, 0-160Psi,+/-1% Accuracy, 1/4" NPT Lower Mount @ $14.97
Total parts $157.97 not counting case or compressor since. Already had those.
Air down time was 3 minutes and air up was 15 minutes. Not sure how OP got 8.5 minutes. 🤷🏼‍♂️ No big deal. At some point I’ll probably get an ARB.
edit: looked at his pics again. Maybe it wasn’t the exact same compressor…
DaveInSA
Seguin, Texas
Looks like you have the 2780 and he has the 2781. 2780 is 2.54 CFM, 2781 is 5.65.
But thanks for the exact descriptions. Was searching on amazon trying to match up pictures :)
mikec426
Russellville, AR
Yeah, I probably should’ve just posted links. And I found my order. Yup, 2.54 cfm.
