- Jul 23, 2020
- 11
- 2,145
- 3,233
- Denver, CO
- '23 4dr Badsquatch, â05 LJ & â17 F150
- Badlands
My hunch is that they're also having issues with the complexity of Ford's designed hardtop and getting it to seal properly w/ the mod top version (a problem for many jeep owners).Why is no one talking about whatâs changing on the 4 door MIC top for 2022?
Whatever they are improving on the mod top to accommodate a roof rack for a Sasquatch (which is obviously taking longer than expected) is probably the inner design around the C pillars/cross beam.
Youâd think the front and mid panels arenât changing, since theyâre not structural, which is good since itâs going to be very costly if you break a panel down the road on your 2021-only top. Iâm guess itâs just the clamshell inner structure.
I think the consolation of free sound deadening is more than just the mod top delay but also to appease MIC top guys that a part of our top will be a one and done for 2021. I donât think the current sound deadening cut outs will be 100% compatible with any top after 2021 (such as the clamshell) since it will be modified for 2022....which is why it was such an easy decision to unload all of their sound deadening for free.
The fucked up part is that Ford said wait for 2022 to get rails on the Sasquatch. Then said mod tops will be delayed but could still be had in 2021. Personally, I wasnât buying any of that, and steered clear of ordering my 21 with a mod top. Really? They are going to build a mod top for a 2 month production run in 2021 only to modify it in 2022 for better roof rail support? Yeah right. Look where they are now - They wonât even scrape together a couple thousand of them for FE owners.
In short - There will likely be two different structures for the 4 dr hardtops (one that canât support rails on a Sasquatch ie 2021; and another slightly modified for the rails in 2022). The sound deadening cut out now are only compatible for 2021 (MIC only) and are free to everybody. MOD tops will be perfected in 2022, and MIC tops will be modified in 2022. Another reason why they axed dual tops. They just want to get the inadequate 2021 version of the MIC top over with to focus on the revised structure in 2022.
Before we know it, Ford will be telling us that MIC isn't available and soft top only. Just joking.
