webspoke
Stan
Pilot Point, TX
F450, GT350
FYI Xpel now has some pre-cut kits for bronco's 2dr and 4dr. Some of the simpler kits are reasonable DIY.
Xpel 2dr kits
Ford Bronco XPEL PPF film pre-cut kits now available for 2-door and 4-door Bronco xpel kits
campbebc
Ben
Waterford, VA
2021 Ford Bronco, 2019 F-150 Raptor, 2004 Mazdaspeed MX-5
Thanks for posting! Looks like free shipping on all orders too. Just ordered a 12" screen kit for $20 while I sort out my PPF plans
broadicustomworks
Hanging Rock, North Carolina
Exactly the same. Glad to have found it, thanks to @webspoke for the info!
bytheway
Brice
Louisville, KY
Rocker panel kits are intriguing. What's the textured paint? The pinch seam?
Is there confirmation the 12" screen protector is the right one? Someone said the F150 12" screen is different.
edit: looks like it's a different part # than the F150 screen protector so I guess they did realize they're different.
campbebc
Ben
Waterford, VA
It's on the Bronco specific page so I assume it's correct
Zeke013
Oregon
Looks like almost $3K in material to cover most of the vehicle - and that doesn't include the rear tailgate, hinges, etc., that I had done. Makes me feel better about what I spent . . . :sick:😎
Rough Rider
2018 Mustang Convertible
I had the rocker panel above the textured paint installed a couple weeks ago. Above the pinch seam is paint that has a rough texture to it that is meant to deflect stones. On my Badlands its covered mostly by the Rock Slider. I didnt want to have that covered as I was worried the adhesion there would not be as good on the flat surfaces and may cause premature failure. Looks good and you cant tell it is there
My store installed it as MSRP on the website, so I am sure they bought it cheaper than what the website sells it for.
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
Xpel 2dr kits
Just to give people a heads up the DIY kits do not wrap around the edges and thus you will have dirt/grime build-up unless you call them and tell them to extend the edges by 1/4" or so. Also if your not a verifiable detail\Wrap business XPEL don't provide tips or tech support for us DIY. My advice is save a $1,000 if doing a full PPF Wrap and buy bulk. Meaning measure the pieces out and order a sheet large enough to cover that area. For instance the hood is 60in width and 4' length and costs $255. I am not sure how the body contours may affect the measurement yet, but in the next few weeks I will be able to provide my own experience with XPEL PPF. Watch a lot of YouTube PPF install videos.
webspoke
webspoke
Stan
Pilot Point, TX
F450, GT350
I am planning on the a-piller , rocker, and small hood. Also the headlights as well.
dfresh73
Doug
Kentucky
Range Rover
Yeah noticed that a week ago, so expensive, so very very expensive. :unsure: :cry: ;)
Same here. I took one quick scroll through and kept on going. I'll probably get the screen protector though.
EcoBco
Kevin
SE Michigan
Wondering if the wear and tear kit is for the lower doors and behind the handles?
Bronco4lyfe85
William
2019 Challenger Scat Pack
Perfect! Exactly why I cancelled the PPF from the factory. I’ll cover the front of the car myself.
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
Try buying for a bulk install and the cost is about $1,500. It is also the best way to do the install on the Bronco.
