285/70/17 or 285/75/17 on 2 door Bronco with stock wheels ?
Kaydee21
Khalil
UAE
Ford Bronco
Hi Guys, this may have been asked already so apologies in advance.
Just got my 2-door Bronco and want to install new tires on stock wheels without a lift and no removal of crash bars.
How do 285/70/17 vs 285/75/17 compare, and will they affect overall off-road/on-road performance?
Any pictures of a 2-door with 285/75/17 and no lift would be super helpful as well, just so I can see what that visually looks like as i already know it looks awesome on the 4-door.
Thanks!
GroovyGeek
Boyan
'23 Bronco BD
Not an expert but... simple math says 30mm more lift (and diameter) m, 15mm more ground clearance. That's about it. Neither should rub... I think.
HoosierDaddy
Indiana
Seems like it has been done and they were able to retain the crash bars on several rigs here.
With factory wheels at +55mm offset, you have a rub at full lock, but with wheels similar to Squatch at +30mm you should not.
The 285/75 is probably the tallest you can go without removing the crash bars (33.9") .... but , just for reference and to show that all of these Broncos were made to fit up to 35" tires ... here's my baseBase with 35's (34.5"), a mere . 6" more than the 285/75's.
https://www.bronco6g.com/forum/thre...no-lift-method-703s-toyo-35-x-11-5-17s.32232/
before/after
Ford Bronco 285/70/17 or 285/75/17 on 2 door Bronco with stock wheels ? 1699598071194
Ford Bronco 285/70/17 or 285/75/17 on 2 door Bronco with stock wheels ? 1699598128559
Kaydee21
Kaydee21
Khalil
UAE
Ford Bronco
before/after
Looks awesome. Thanks a ton. I think I'm just going to go with the 285/70/17 for now without a lift/crash bar removal while retaining stock wheels. I'm thinking of BFGoodrich 285/70 R17 121/118R All Terrain T/A KO2 .
Bob 07064
Bob
Somewhere in time and space
02 4x4 ranger, '17 edge 2022 Bronco
I used rims from the ranger with the 285's
Kaydee21
Kaydee21
Khalil
UAE
Ford Bronco
Ford Bronco 285/70/17 or 285/75/17 on 2 door Bronco with stock wheels ? 20231103_171224
sweet! 285/70/17 or 285/75/17? did you remove the crash bars at all? any lift? funny enough, i have the same color.
Beach_Bum
Ken
St. Augustine, FL
For reference and future comparison, you can plug in the parameters in the tire calculator at Tire Size:
Ford Bronco 285/70/17 or 285/75/17 on 2 door Bronco with stock wheels ? 1699615857439
The height gain is achieved by the greater sidewall. The width (285) stays the same. You should have no issues choosing either tire on your stock +55 offset wheels. The stock crash bars can remain. Or if you want to maintain crash bars, there are replacements from 4WP. Boss4x4 has them on sale.
Bob 07064
Bob
285 70 17... no lift or crash bar removal. I went with Milestar Patagonias since I only intend on some mild off roading and beach combing...
Kaydee21
Kaydee21
Khalil
UAE
Ford Bronco
Awesome. Any issues with the spare tire fitting on the rack at all?
Bob 07064
Bob
I had to remove and trim down the bumpers that stabilize it on the tailgate.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
before/after
Wow! What a transformation! Great looking rig! Thank you for sharing.
