Stock Big Bend with 285/75/17 on Stock BB wheels
broncbeau
Beau
15 Sierra
I put some bigger shoes on this whip. I was going to level it but decided not to. I put this size on because it was as large as I was comfortable with on the 7.5 Big Bend rim. The crash bars didn't rub but I removed the rears anyways.
Zero rub in full lock and full lock reverse. The tires clear the first crash bar by 1.5 inches and the control arm by 1.25 inches.
B
Edit: FYI Tires are nitto ridge grapplers that nitto specs at:
33.86"11.26"
Ford Bronco Stock Big Bend with 285/75/17 on Stock BB wheels PXL_20210803_205219391
Ford Bronco Stock Big Bend with 285/75/17 on Stock BB wheels PXL_20210803_205015774
Ford Bronco Stock Big Bend with 285/75/17 on Stock BB wheels PXL_20210803_202057868
FerkinBlonco
AK
2008 KLR 650, 2022 Bronco Base (2dr/7mt/CO)
Nice! Good to know what fits, thanks for sharing 🍻
Heart2
Dan
St. Louis, MO
2022 Bronco Big Bend
Nice Bronco! Just having larger tires really changes the look of your vehicle. Will you have the speedo/odo recalibrated? Who does that? Your Ford dealer? I was thinking a slightly larger tire, than the standard BB tires, like a 275R70/17. I have never swapped to larger tires before. I'm looking for some middle ground for tire size, as I'm not sure I want the Sasquatch package (it's more of a budget issue, but I like how the 35s look).
broncbeau
broncbeau
Beau
15 Sierra
As far as the speedo goes I'm not sure if a dealer will do it. In a few months there should be some aftermarket tune companies that can calibrate for the size difference. This BB has the 2.3 and it did not make a noticeable difference in power loss to go to the large tires. Fyi these tires were $305/ea and the shop gave me a $350 credit for the stock Bridgestone Duelers. The total was $1061 for the new tires. Probably the least expensive way to get it looking like a proper Bronco.
peterh
ny
jeep wrangler jlu 2018
to me that tire is perfect! nice height and for me the best part is the width, more of the traditional skinny look
aherried
Adam
Oklahoma City
21 Bronco
Thank you for sharing! I ordered a BB, 2.7L, MIC, Tow Package, in black, and this is the only upgrade I was planning on putting new set of tires and/or wheels on.
AmericanFreedom
Illinois
Ford Bronco
B
33.86"11.26"
hot dang friend! looking great đź‘Ť ya think you will level eventually?
broncbeau
broncbeau
Beau
15 Sierra
I think if I would have put 35 11.50s on I would have used the 1" level. There's so much room this one is probably going to stay stock.
B
gabagal
Gabby
Ohio
2017 Mustang Ecoboost
No issue with the almost 34s? I really want to do 285/75/17 on my OBX on Vision Fury rims.
broncbeau
broncbeau
Beau
15 Sierra
Zero. Some dude put 315 70 17 on his base and has minimal touching as well. Just know your wheel offset will effect how the tire sits. You can see offset differences at tiresize.com
theserg
Sergey
FL
Ford Bronco Big Bend
What has your MPG been with the bigger tires? Looking at KO2s
broncbeau
broncbeau
Beau
15 Sierra
I'm probably not the best at mpg cause I drive it like a Porsche. But it was 17-20 depending on how it was driven before and not much has changed.
theserg
Sergey
FL
awesome, no crazy road noise either?
1975U15
2019 F-350 SD, 1975 Bronco
Thanks for sharing OP. I’m a little nervous I’ll be close to rub on front end crash bars. I’ve ordered 295/70 with +12 off set. Obviously no rub with crash bar is ideal.
Already wishing I went modular bumper for tougher look and ease of removing end caps to pull crash bars. Looked like bumper needs to come off to pull bars on non SAS OBX??
