Stock Big Bend with 285/75/17 on Stock BB wheels
dgorsett
colorado
F250, Mustang, Explorer
Discount tire will definitely install this for you.
Big Diamond?? I fixing my Big Bend to be like a Black Diamond, hence i call it Big Diamond..
I like the Black Diamond features but wanted cloth and liked the BB wheels and grille best.
Big Diamond
Miles
Atlanta, GA
2022 Bronco HOSS 3.0 Wildtrak
My first Bronco was a Black Diamond that I was going to lift and put bigger tires on, hence my name. I went another direction, ordered a second bronco, and now have a Wildtrak with HOSS 3.0 suspension.
Jsullivan
Jay
2018 Explorer, 2016 F350 Diesel, 2013 Explorer
As far as the speedo goes I'm not sure if a dealer will do it. In a few months there should be some aftermarket tune companies that can calibrate for the size difference. This BB has the 2.3 and it did not make a noticeable difference in power loss to go to the large tires. Fyi these tires were $305/ea and the shop gave me a $350 credit for the stock Bridgestone Duelers. The total was $1061 for the new tires. Probably the least expensive way to get it looking like a proper Bronco.
Follow the directions in this Forum and use Forscan.
I changed my 2 Dr Base to 285/70 R17 KO2's it's an easy fix.
I immediately changed to the KO2's so I don't have a MPG comparison to stock but I"m getting 23.4 MPG avrage over the fist 6500 mi, with a Base 2.7 and 3.73 gears.
I also added a KN filter and Magnaflow Axle Back dual exhaust.
I always run 89 Octane.
Green Nv
George
Ohio
Ford truck/Bronco
I put some bigger shoes on this whip. I was going to level it but decided not to. I put this size on because it was as large as I was comfortable with on the 7.5 Big Bend rim. The crash bars didn't rub but I removed the rears anyways.
Zero rub in full lock and full lock reverse. The tires clear the first crash bar by 1.5 inches and the control arm by 1.25 inches.
B
Edit: FYI Tires are nitto ridge grapplers that nitto specs at:
33.86"11.26"
Looks like that'll do er for me. Thanks for the pics of your ride and the info. I'm ordering them new skins today.
Lintlicker
Phoenix
I just ordered 285/75’s Toyo OC ATIII with the 17x9 KMC Trek + 18 because the old dirty Harry’s are stuck on a boat in the Pacific Ocean. Sure hope they fit w/o having to remove crash bars. I intend to get a lift at some point but want to do some mods to enhance its off-road performance I do gotta say, the OBX non sas doesn’t do bad at all of road if you know how to drive half way decently 😬 Will post pics before and after on the “new shoes” thread.
dj101nyc
Harry
New York
www.instagram.com
Big Bend w/4.27 & rear dif
B
33.86"11.26"
Joined the 285/75r17 Club today with the Cooper Discover XLT 33.8" diameter & 11.5" width. So far so good, no rub or real difference in drive quality or noise.
Lakelife36
Ben
Interior of BC
Does anyone know if a standard tire place (like Discount Tire) will put this size on a Big Bend. All the sites show the tire will not fit the model so I'm skeptical they may refuse to change them out.
My tire guy won't sell anything over 3% difference.
Moto26
Tucson AZ
Meloco
Bronco edge excape
What two tires sizes that are being compared in the picture above
