- Joined
- Feb 15, 2022
- Threads
- 49
- Messages
- 160
- Reaction score
- 126
- Location
- Boston
- Website
- www.offroadalliance.com
- Vehicle(s)
- Bronco
- Your Bronco Model
- Base
- Thread starter
- #1
We just got in some awesome DV8 bumpers for the Bronco and they're ready to ship out ASAP! In a world full of long lead times it's nice to be able to order something for your Bronco and be able to get it soon after. We've got 3 styles of DV8 bumper available: the OE Plus Series, the MTO Series, and the FS-15 series. Below you will find a detailed description of each bumper and can find out which one suits your Bronco the best.
PM me to make an order today!
Shop DV8 for Bronco at Offroad Alliance
OE Plus Series Front Bumper
The OE Plus Series is a Low-Profile Front Bumper for the 2021-2022 Ford Bronco. This was designed to fit the form of the Bronco as tight as the OEM bumper.
The front panel was designed to match the grille of the higher-tier trim levels, although it looks excellent with the lower-tier trim levels as well.
Behind this cutaway pattern, a Dual Row 20-inch LED light bar can mounted. It features pod light mounts on each side of the bumper, that fit 2 pods each.
Features:
MTO Series Winch Front Bumper
The DV8 Offroad MTO (Made to Overland) Series Bumper is a Winch-Ready Front Bumper for the 2021-Present Ford Bronco, and is compatible with all trim levels.
Manufactured from high-grade steel, the MTO Series Bronco bumper retains the factory sensors, has a 3-inch pod light mount towards each side, and mesh inserts that can be painted. There is an optional bolt-on bull bar that can mount a 13-inch LED light bar to supplement your lighting.
The winch mounting point was designed to sit within the bumper, and is accessible through 2 openings at the top of the bumper. It can mount up to a 12,000 lb. winch. If you choose not to run a winch, we include light brackets to mount a single row 20-inch light bar behind the perforated aluminum accent plate.
The Adaptive Cruise Control sensor module must be relocated if the vehicle is equipped with ACC. Our ACC Relocation Bracket is sold separately, available in the drop-down options to the right.
Features:
FS-15 Series Winch Front Bumper
The Bronco FS-15 Series is a 2021-2022 Ford Bronco Winch-Ready Mid-Width Front Bumper, with the option to include modular wings to make it a full-width bumper. The light mount tabs on the bull bar can be oriented to mount a 13-inch light bar above or below the bull bar.
Up to a 12,000 lb. winch can be mounted on top of the bumper. At the center of the bumper, either a 20-inch dual row light bar or 6 pod lights can be mounted.
Two recovery mounts that take 3/4 inch D-rings provide additional recovery options. This bumper is compatible with the OEM plastic and metal skid plates, and also retains the factory parking sensors.
Features:
Features:
- 20 Inch Dual Row Light Bar Mount
- (4) 3 Inch Pod Light Mounts
- 3-Piece Design
- 2-Stage Powder Coating
- 4mm body and 5mm mounts/supports
- Reinforced D-Ring Mounts
- Compatible with Factory Plastic and Metal Skid Plates
- Does not Interfere with 360 Degree Camera
- Works with Factory Parking Sensors
- 3-Piece Construction
Note: Vehicles Equipped With Adaptive Cruise Control Will Need To Relocate The Module Using Our Abbr-01 To Retain The Functionality
Features:
- Optional Bull Bar
- (2) 3 Inch Pod Light Mounts
- 4mm Body and 5mm Mounts/Supports
- In-Bumper Winch Mount
- Paintable Aluminum Mesh Panels
Features:
- 2021-22 Ford Bronco FS-15 Series Winch Front Bumper
- Optional Full-Width Wings (FBBR-02W)
- Adjustable Bull Bar Light Tabs
- 3.5mm Body and 5mm Mounts/Supports
- Winch Ready
