The_Axeman
Sean
Montréal, Québec, Canada
2021 Ford Bronco 4dr Badlands 7MT
So I’m about to embark on a little road trip 😉. Roughly 4300 miles. I’m going to spend a few nights in the Bronco (roughly 5-6 total) and wanted a flexible and easy solution that would provide me adequate space, comfort and ease of setup. Although I’ll be going it alone this time, I wanted my platform to match the 60/40 seating and give me the option of going single or double.
I decided to use 5/8” plywood to keep things fairly light. I also decided on only 2 supports, allowing me access to my floor compartment. The supports are 6” tall and the platform ends up perfectly flat. I’m really happy with the result! I’ve also installed some Velcro tabs around the vehicle and have blackout curtains that surround the entire sleeping area. It takes me about 5 minutes to be completely ready to sleep (platform unfolded, curtains installed and air mattress filled). This option leaves you with an uneven trunk space when the platform is folded up and stored - but that wasn’t a big deal to me. It takes me about 10 seconds to put it in the Bronco or to remove it. I don’t have a scale but this thing’s pretty light. Maybe 35lbs. I also love the hidden storage that it provides if going topless.
I’m 6’2” and 230lbs and I fit without a problem. With my previously made (and posted) window vents and a battery operated fan/light that hangs from a roof latch, as well as my headrest mounted iPhone/iPad mount - I’m all set up!!!
Before anyone comments - I’m gonna replace the orange webbing with black - but I already had it and at least it matches my Badlands trim 😉. Hope this inspires some even better ideas.
Ford Bronco DIY single or double sleeping platform F060E8AE-6767-4F36-96A0-75E5CFC863A4
Ford Bronco DIY single or double sleeping platform C4DFA051-3594-4130-8F25-CE1ADF73BA5C
Ford Bronco DIY single or double sleeping platform 213F79B8-495E-426E-841A-E70F9309C0CC
Ford Bronco DIY single or double sleeping platform CFEE3705-A297-4C32-A558-61A099C527C7
Ford Bronco DIY single or double sleeping platform FE1775E2-377C-46A3-B751-7D87E500C7A4
Ford Bronco DIY single or double sleeping platform 45C6F40D-076C-4104-B6A2-0D7B6C789CC2
Ford Bronco DIY single or double sleeping platform 83CE9E70-C9D9-487A-AC50-1490DDB1D0CA
Ford Bronco DIY single or double sleeping platform F9A6D661-EC1C-4C31-B8D4-366A662B9047
Ford Bronco DIY single or double sleeping platform 056B31C6-486B-46A3-9BF9-5756D1BDCCBE
Ford Bronco DIY single or double sleeping platform EDAE9A64-AC16-4450-A556-1FA0D2B42D86
Ford Bronco DIY single or double sleeping platform 28600F2D-0C91-45B9-B73B-1C182000A98A
UncleBuck
Washington
2011 Ranger XLT 4.0L - 4x4
This is my favorite solution so far. Nice work. I was thinking that incorporating the seat backs to support a little more length on the platform would be possible. I might be stealing this one.
Kos
Omaha, NE
2022 Ford Bronco Badlands
I like. Planning Off-Roadeo at Moab this summer and my wife shocked me when she got a mattress to sleep in the back of the Bronco. Maybe something like this will make that more feasible.
Julz670
Julian
Minnesota
www.youtube.com
Previously: '83 and '95 Bronco XLTs. RIP.
I like your setup. Are the orange straps intended to take some weight off of the folded rear seats or just simply hold up the last section of your platform? Just asking because idk how much that plastic trim on the back of the driver seat will hold before they snap off. But it looks like there wouldn't be much weight there anyway, just your pillow and head area, the rear seats and rear-most section of your platform look like they would take the majority of any weight on top. Plus a mattress would spread out the weight too. So i guess not much of a concern. Ignore me haha
choppersean
Sean
Arvada, CO
'22 Badlands Sasquatch, 2-door, EG, 2.7, Auto
Very nice solution! I love the 60/40 split. My Nissan Xterra has 60/40 and the seats go completely flat, so I will miss that with my new Bronco. I'm a backpacker and often will drive to a trailhead late in the evenings and sleep in my vehicle so I can hit the trail early the next day.
Also, the 60/40 split will still allow me to carry gear and a backseat passenger if I need that room as space is limited with my selected 2-door.
The piano hinges and "Z-fold" stow-away just gives ultimate flexibility and some hidden storage........very nice!!
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Nicely done! I also like the placement of your Badlands badging in the back.
Jay634
Jay
Toyota 4Runner
Great set up. Simple and very functional. I've been anxiously awaiting mine (hopefully delivered in March) and was going to start working on a platform right away.
The_Axeman
The_Axeman
Sean
😂. Yes - the tabs hold the last folding section of platform- which- as you mentioned- only hold up our heads. And if you’re an airhead like me - that’s next to nothing 🤪
However - because the force that’s exerted is essentially downward- those plastic hooks will still hold a decent amount of weight. The only thing I would suggest - as others have done on their platform designs - is to place a removable support in the void space created towards where the back seats hinge when folded down. I was in there working on putting up my curtains the other day and sat my big ass, crossed legged, right on the unsupported side of the hinge and it started cracking. I weigh 230lbs and the weight was pretty focused on one spot, so….
But I ripped a piece of 2”x6” to 2”x3.75” instead and it supports that area. I just place it there before unfolding the platform.
The_Axeman
The_Axeman
Sean
zebraquick
Rick
Amarillo, Texas
2017 Kia Forte
Looks great. Where did you get your extinguisher?
djp
djp
Idaho
'22 Badlands 4dr || '21 Bronco Sport BigBend
What kind of 5/8 plywood was used? Where did you buy? is it pressure treaded?
Also those 6" supports are they 2x6 pine, non pressure treaded ?
Where did you find the hinges please?
Thx... if you can provide more details that would great!
looking for a shopping list sort of :)
Bravo, great work, best i've seen on forum!
The_Axeman
The_Axeman
Sean
At a local hardware store. The size was perfect and it’s been installed for a good while just using 3M mounting tape. I’ll see if it holds up to some good off-roading when I hit up ‘Ol Florida Off-Road Park during my road trip. 🤞🏻
