- Aug 27, 2020
- 10
- 628
- 1,124
- Louisville
- 2009 Honda Pilot
- Badlands
Just needed to adjust his coil overs.
Im looking at this same tire myself but plan to do a small lift. Not sure which lift yet. Badlands no sas.Likely your best option.... but the rims should not have any issues mounting and running 35's.
Those look great. I kind of wish I had ponied up for the optional wheels on the badlands. Do we know if these have the same dims as the non-beadlock wheels that come standard on badlands?OK- here is the skinny-
315 BFGâs fit and just kiss the upper control arm at full lock. You will need to trim the rubber bumpers (about an inch) on the tailgate to get the spare to fit without modifying the carrier. I tried the Sasquatch flares, but the tires donât have enough offset to poke enough so i left the standard flares on.
72.6 pounds is light? Compared to what? Sasquatch tires are 52#, Badlands stock tires are 51#, 315/70r17 BFGâs are 62#.Nitto makes a 35x11.5r17 that's in C load so much lighter and not as rough as most 35's
https://amzn.to/3mUc2Nu
Thanks for posting. Looks really good. Considering the same swap because I do like the wheels. These are 12.5" wide correct? Would a 1" level in the front prevent the slight full lock rubbing or is it a width issue?OK- here is the skinny-
I donât think a level will help, it is an offset issue so spacers are probably the only option.Thanks for posting. Looks really good. Considering the same swap because I do like the wheels. These are 12.5" wide correct? Would a 1" level in the front prevent the slight full lock rubbing or is it a width issue?
Is this the exact product you bought (class C)? https://www.4wheelparts.com/p/bf-goodrich-lt315-70r17-tire-all-terrain-t-a-ko2-07361/_/R-BDKZ-07361
17x8, same as the standard Badlands wheels.Does anyone know what the width of the optional, not Sasquatch badlands rims is? 17x9?
For the uninitiated - thatâs typically referred to as âthey donât/wonât fit b/c they rub my sway bar at full turnâ. Insurance adjusters love when the vehicleâs critical systems (steering) have been compromised. So that would apply to anytime the vehicle is in motion. So called road worthiness. And yes, wheel choice is such an easy and obvious part of the vehicle to target to deny coverage. Some will even have trouble with tire choice away from stock, but if you can prove the tire doesnât impact the vehicle in any condition - then theyâll let it go. Iâve had 2 incidents that this was an issue - fortunately there was no wear on vehicle and I proved lack of impingement - the line in adjustment was - oversized tire choice has compromised road worthiness and is the basis for denying coverage for . . . Including leaving me liable for other vehicle. By accident (pardon pun) my tires were overrated as that was the next thing regarding compromised stopping. Crafty folks. I run 33âs on a stock outer banks and have video of wheel clearance on file.Not a prob on mine 35s with ++55 offset..very slight rub on sway bar at full turn..prob not if your a crawler or aggressive off road...
