35" Tires on Stock Badlands rims?
96GreenBronco
Andrew
Fl
1996 Ford Bronco XLT, 2021 Ford Bronco Badlands 7M
I am seeing lots of people upgrading from the stock 33" BFG tires and rims to a 35" tire on the Badlands but they all seem to change the wheels/rims as well.
My question is, does anyone know if you can just put some larger tires on the stock (non-beadlock) rims and not add any lift? I think I saw crash bars may need to come out, but otherwise suspension is very similar to sasquatch...
Thanks for any thoughts
treadlightly
Montreal
_
If I recall correctly, the verdict was they will fit but off-roading with them may be a problem (yes video title says 37s, but they started with 35)
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
Kenda makes a 35x10.5x17 that would work on the stock rims. I think most 35” tires are going to be too wide for the stock rims. If you can deal with a 34”, there are several nice options.
False
F-150
I’m pretty sure you’ll have issues with the offset because that’s a major difference between the Sassy rims and the stock badlands that deals with clearance. Crash bars will have to be removed but that’s pretty easy.
M Redwood
M
Prescott az
2022 BB,BASE
Not a prob on mine 35s with ++55 offset..very slight rub on sway bar at full turn..prob not if your a crawler or aggressive off road...
iamchewby
Chewby
It's only 1/2" difference on the lift between the BL and sas, so the height isn't an issue. A 315/70r17 will be fine on an 8" wide wheel, so that's not a problem either. The only issue is the +55 offset. A 1" spacer will fix that, and yes, spacers are fine as long as they are quality, just don't buy ebay/amazon spacers and you're good. Go with Bora spacers. Then just remove the crash bars and boom. Done.
Arc
Alan
Sc
Gmc 1965 4x4 SS Elcamino 72
The old question asked again, can i fit on a Non SQUATCH Black Diamond 285/70 r17 using a 17 inch 35 positive offset without rubbing or removing or modifying front coils. any pictures of the look.
MacDonald_Photo
Jamie
Eaton Rapids, Michigan
2021 Badlands
Thinking I might do the same if I can find a tire that will fit properly...Certainly watching this thread for ideas.
BossMann
Louisville
2009 Honda Pilot
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
He's 6' 3". He mentions that in most of his videos.
Fell right into my trap.
He's yet to make one video he does not mention it.
