The 2.7L was one of the first Ford engines to go back to an oil pressure transducer from the "dummy gauge" switch they started using back in the late 80s. Since my Bronco is stuck in 6/28 build week purgatory I don't know if you can get an oil pressure readout from the IPC but you should be able to read the pressure from a scan tool like Forscan.
