Amazon Skid Plate
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
ksdon
kansas
It clearly says it will replace the original plastic SKIT plate.
All joking aside, it could be a worthwhile upgrade to a plastic plate.
I like that they suggest sending a photo to help assure fitment. That shows some level of care.
JMY217
Joe
New Jersey
2022 Ford Bronco Outer Banks Sas/Lux/Soft Top
Would love to see how this turns out. The plastic skid is with the standard bumper, correct?
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
If you are going off road its certainly a decent option. If I was only driving on pavement I wouldnt bother at all. What thickness is fords steel skid plate vs this one at 1/8th?
dgorsett
colorado
F250, Mustang, Explorer
It looks like it uses the back (slotted) and middle (tow hook) bolt locations and not the front two, probably to allow use with aftermarket bumpers. Probably OK.
NewBroncoOwner
NewBroncoOwner
Good Ol USA!!!
I sent a photo with the question of fitting around the tow hooks.
Dmorty217
Derek
Venice FL
Camery
For $109 you won’t find a cheaper option, worth the risk of having to hit the UPS store to return it if it doesn’t work
NewBroncoOwner
NewBroncoOwner
Good Ol USA!!!
that was the big selling point for me, they take returns. There is only two options with this purchase, it works, or it doesn't lol
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
It's missing the 2 bolts (red) that tie it to the front bumper. And I dented the brackets behind the green circled bolts before punching a hole in the factory plastic skid. I wouldn't call this an improvement, most likely going to damage the intercooler if you hit something to hard.
NewBroncoOwner
NewBroncoOwner
Good Ol USA!!!
We will see if any fabrication is needed or if it is a bust. I should have it in hand on Friday, 9 SEP and installed on the 10th at the earliest. I'll keep y'all in the loop.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Ford Bronco Amazon Skid Plate 41KnJDO6A9L._AC_SY350_~2
I damaged my intercooler with the ford steel bash plate. I got a little too carried away in the whoops. So it may be comparable.
‘21OBX
Ken
90Bronco19
Now I don't feel so bad about denting mine.
Mine doesn’t leak. I hope it holds up long enough for the mishimoto high mount intercooler to be done. Then I won’t have to worry about it anymore. Didn’t feel like that hard of a hit in the sand dunes.
Ford Bronco Amazon Skid Plate 8C19F1CB-1351-4647-85A3-0081C63E6108
