- Jul 24, 2020
- 896
- 3,422
- Pittsburgh, PA
- 13 10A Rubi, 14 HR Rubi, WRX, 19 Edge
Nice to see you can speed up in 4Low and then slow down and stays in 4Low.
...why would it not?Nice to see you can speed up in 4Low and then slow down and stays in 4Low.
I hope you are joking.Nice to see you can speed up in 4Low and then slow down and stays in 4Low.
Not sure what your YJ does in 4L but I’ve had 2 JKs and you really can’t go past 20mph in 4L, at that point you’d better change to 4H but this appears the Bronco let’s you go a little faster.I hope you are joking.
I think it stayed in 4L. The drivers may have been pointing out the wide range of the 10sp made the effective speed range in 4L broader than other transmissions would have in the past. All the videos I have seen require N to engage or disengage 4L. But, with all things Bronco, I could have that wrong....why would it not?
Edit: NM; I guess the 4L shift was done all via GOAT mode, and I could see how it could be programmed to try and force you out after a certain speed.
I was looking at it as "why would it automatically shift you out of 4L based on speed?" I've never been in a vehicle that did/ does that.I think it stayed in 4L. The drivers may have been pointing out the wide range of the 10sp made the effective speed range in 4L broader than other transmissions would have in the past. All the videos I have seen require N to engage or disengage 4L. But, with all things Bronco, I could have that wrong.
