Anyone having brake issues?
TK421
TK
Chicago
I've read a bunch of people complaining about how soft the breaks are. I feel the same but the last week after starting the car in the morning the breaks start squeeking.
Takes a few miles for them to finally stop squeeking. Going to bring it to the dealer but by the time I get it there they stop squeeking.
I'm 3500 miles in. Anyone else having this issue?
Deleted member 12876
Guest
That’s just dust making the brakes squeak a little bit
CCross
Cory
Arkansas
2007 Chevy 2500HD Duramax, 2000 Jeep Wrangler
Something on your Bronco is broken? Jk. The problem with your brakes squeaking is probably no problem at all. The brakes on my work truck have squeaked in certain situations since new pads were installed. I think it’s just the nature of the materials used to make them now. They work as advertised otherwise.
buck_6G
Austin, TX
Toyota Tacoma TRD Pro
Could be a caliper issue causing partial contact with the rotor. I'd get it checked out. You shouldn't expect your brakes to squeak. Ignoring the problem is not a strategy.
Theherofails
Thomas
Phoenix
Psh, thats how I get through most problems in life. It works.
SolidSnake
Dante
No
No problems with my breaks and I'm at about the same mileage
da_jokker
Jeep Wrangler JKUR
Brakes can easily squeal. If they get dust or dirt in them, or if there's a lot of moisture outside, you'd be surprised how quickly they can develop surface rust. But if the squealing goes away soon after you start using them you're fine. Next time you wash your car Make sure to get in there to get the dust out.
The squealer indicator for low pads will be very distinctive when you apply the brakes and does not come and go.
