Anyone running dual under seat subs? 46HS10
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Anyone running a 46HS10 under each front seat in stereo? Is it worth the effort?
Any reason to disconnect the factory sub when going this route?
Edit: or dual subs under rear seats.
mdube72
Matt
NH
Audi SQ5
@Rumbloki Did you end up going down the 46HS10 path ?
Rumbloki
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
mdube72
Matt
NH
Audi SQ5
I haven't made a move yet. I mentioned under front seats, but under rear seats may be better (4Dr).
@Rumbloki - I'm still on the fence too. I have 2dr so not much space. Looking at harnesses now
Sloth
SWFL
2022 Bronco
Dual subs are better than singles. However, they don't need to be wired for stereo as bass is non directional. Definitely disconnect the stock sub.
Wtb13000
Wyatt
New Jersey
2023 Bronco
Why disconnect stock sub? Wildtrack owner here if that matters.
mpeugeot
The 46HS10 won't fit under the seat of the 2 door from what I remember (but I often keep my seat in the lowest position).
Sloth
SWFL
2022 Bronco
The 46HS10 (single or pair) would more than cover the frequency range of the stock sub and sound a lot better while doing it. There are also more technical reasons such as overlapping frequencies and significantly different power levels making such a setup hard to tune. This is what I would do if it were my setup. Others might not care or even notice.
