DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
SEND IT
brilltastic
Matt
Atlanta, GA
Toyota 4runner TRD Pro
AR | STIRRUP
The BRONCO community asked for it and we went to work! After reviewing what was shared from last year's SEMA Bronco, there was plenty of room for improvement, both in design and function.
Made from a sizeable chunk of 6061 billet, the STIRRUP is very beefy part and it will look right at home on an overland build, trail conquering rig, or your daily driver. It's five inches of width will give your boot or shoe a proper platform to assist you in climbing up in the saddle. The entire part is coated in RAL 9011 Graphite Black, then post machined to remove the coating from the top surface and reveal the raw billet aluminum and provide a very classy contrast. This will also give the STIRRUP years and years of rugged good looks. The more you step on the the more naturally worn the aluminum will look but it won't affect the Graphite Black coating.
The STIRRUP is mounted to your OEM rocker rail with M8 and M10 316 stainless fasteners. A single M8 bolt alone has 110,000 PSI tensile strength! The STIRRUP is definitely more solid than the rail it's mounted to. With its coating and the use of aluminum and stainless, the STIRRUP will require little maintenance and it will last the life of your Bronco.
The STIRRUP will be sold in pairs. This will also be a BRONCO6G exclusive part, at launch, and B6G members will always be eligible for the 20% discount. We're going to handle the purchasing a little differently this time....
Pricing:
Retail price for the AR | STIRRUP is $494.43
BRONCO6G members are eligible for a 20% discount, making the price per pair: $395.55
NOW TO THE FUN PART:
If you would like to pre-order your STIRRUP pair or set of four now, here's what you'll need to do.
1. Reply in this thread: SEND IT!
2. We will PM you with a one time use code for the ARCHETYPE RACING website.
3. Go to the link, also provided in the PM, to the STIRRUP, and you'll be able to check out with the BRONCO6G 20% discount.
4. Spam F5 on the tracking link, once you have it, while you're waiting for your STIRRUPS to arrive.
View attachment 194217 View attachment 194216
View attachment 192340 View attachment 192341
Send it!
Draughon
Daylon
Dallas
BMW 4-Series
SEND IT
Gotdesl
Alan
Rifle, CO
2016 Ram 3500 Megacab 4x4
I'm in based on the 2 door render. I have to say, you are starting to make my Bronco look AR sponsored. Love it!
Go ahead and Send It...
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
Any potential updates on when these might be produced and shipped?
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I'll cover the shipping. You'll need to slide your Customs Broker a bottle of Maple Syrup or something to help those Duties cost. :)
Send mine with 604BRONCO’s order, I’ve got a broker! lol
DUSTYcazOREGON
Craig
<RESERVED>
Will the newest version of this step still require drilling and is the drilling done on the outer side or under side/back side of the rock rail? Curious as to how difficult the installation will be. I am mechanically savvy....just older and my body won't do what it use to. Thanks...great looking product!
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
AR | STIRRUP DROP BRACKET
Renders are below. The drop available from the standard STIRRUP is difference making 2". The drop bracket is substantially larger than the standard bracket. The STIRRUP Drop Bracket has been updated to the listing on the website as an option. For the majority of use cases the 2" drop would make a lot of sense.
The Drop Brackets retain all of the same ruggedness of the standard brackets. The exact same rail mount locations are used between the two brackets. So if for any reason you want to swap to a drop bracket down the road, it's a simple order and install deal. The Drop Brackets retain all of the same ruggedness of the standard brackets. They do hang down just that little bit more, so that's something to keep in mind if you do happen to find that trail with large rocks.
Drop Brackets are added to the website as both an option and will also be added later as a stand alone product. If you already have the STIRRUPS on order but want the Drop Brackets instead, email [email protected] with your Order Number. We'll make the note to your order on the back end so you receive the brackets you want, but you'll check out on the website for the new brackets, if it turns out that there's a substantial cost difference. There is no cost difference to change your order to the Drop Bracket.
Ford Bronco AR | STIRRUP®  OEM Rail Fitment, Billet Aluminum Side Step - Brongo6G Exclusive Part AR Drop STIRRUP 2.PNG
Ford Bronco AR | STIRRUP®  OEM Rail Fitment, Billet Aluminum Side Step - Brongo6G Exclusive Part AR Drop STIRRUP.PNG
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
That seems to make total sense. Really looking forward to actual photos!
Does the STIRRUP itself come with the base hardware and the drop bracket is additional? Thinking maybe regular height may be adequate for myself, but drop for the kiddo. That may look weird - but, it would be nice to have the option.
Cheers!
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Cheers!
Right now, it's either or. When you place an order now, you can chose the Standard Height or Ummmm Drop (2 in)!
I'll add the Drop Bracket set to the website soon. Probably will not be the least costly of brackets you'll ever see, but 2 doors get 6 of them and a 4 door would get a dozen. It's also a safe bet that there has been more engineering and design time spent on just the AR brackets than most anyone else would spend designing the whole step assembly.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Thank you for making them optional!
I plan on keeping my order with the regular brackets. Then once I try them out I’ll order the drop brackets separately later if need be
