Arb summit bumper
jdubby
jdubby
1995 bronco; 2021 bronco
if y9u guys have the badlands or a model with skid plates...were you able to use the factory skids? Thanks!
JIMMYD
jdubby
jdubby
nm...all good...install successful
jdubby
jdubby
Did anyone have to upgrade the springs? I have a BadSquatch and curious about the stock springs handling this.
just finished the install...zero issues with springs...rides and handles like a champ. I dont have the winch yet...but i'm not worried about that additional weight.
mini4mw
W
Atlanta
Tundra
What size camera extension did you use (if you did)? Pic?
jdubby
jdubby
I used a 12" extension...got it off of Amazon...plenty of length. I do have to make some adjustments for the adaptive cruise control...i do not have enough length for that one. super happy with the bumper though...will post pics at a later date
VentureBronco
CA
2022 Base Sasquatch 2-Door
JIMMYD
did the factory skids work? Wondering if this would Work with the RCI skids (that work with factory bumpers)
jdubby
jdubby
yes...they worked...zero issues...seamless integration with bumper...it is well thought out.
jdubby
jdubby
Just finished the install. All lights are operational with the exception of the turns. I did it want to do them. Also rerouted the ACC and added a spacer to the bumper. No crazy issues.
sklnbnzaz
Graham
Phoenix
Bronco, Ranger
Here is mine installed. Waiting for the Diode Dynamics fog lights.
The bumper moves the camera, the radar and all parking sensors. The license plate mount came with it.
Only issue I've had is the camera relocation is for no front plate so you can see the top of the plate on the screen.
Ford Bronco Arb summit bumper 58905012-9592-40E7-B139-30CC8D8CECB5
We just got back from a 3600 mile road trip. A lot of winding mountain roads. Running with the stock suspension and you can tell there is extra weight on the front but it isn't too bad.
I have one on my Ranger and absolutely love it, considering this for the Bronco as well. How has it been to this point? Also, did you have to rotate the winch clutch? (I did for the Ranger).
Inlinejohn
WA
Several
Got Summit waiting in my garage for Bronco to arrive. Have a friend that installed his long ago. Loves it. I do plan to upgrade suspension
JHawk
Ray
Heartland, USA
Fusion Sport
This appears to be the beefiest option that offers great protection. I assume that the winch cannot be added later without removing the bumper. Is that correct?
Dan66
Dan
Bc
2021 explorer platinum 2014 ram limited
this is the best choice of bumper I can see how beefy it is and Had concerns about upgrading the suspension to handle all that weight 300 lbs? and was looking at the old man emu kits but alas nothing for the Two Door ! but if you guys did not need to that great!
Inlinejohn
WA
Several
Anyone tried leaving camera in grill and what is changed view?
Inlinejohn
WA
Several
Struggling with some hardware. This diagram calls for “packers” and I don’t see anything that would resemble a nylon packer. Any help/thoughts?
Ford Bronco Arb summit bumper IMG_3114
Ford Bronco Arb summit bumper IMG_7356
EL in NH
Ernie
New Hampshire USA
2dr Basesquatch, 2005 HD springer,2010 sporty
you have everything you need already assembled on the two long bolts. packers are washer like and are metal.
Ford Bronco Arb summit bumper Scre
