I ordered all the parts on your list and followed your pictures to match your install. Thanks! It greatly cut down on the time I spent.I finally got around to installing the KR Air Coupler Switch Bracket and ARB Pressure Control Kit. I went overboard ordering hoses and couplers from @4x4TruckLEDs.com, but in the end only needed what is listed below to achieve a clean install.
Parts List:
ARB On-Board Twin Air Compressor
KR Off-Road ARB Compressor Engine Bay Mount
KR Off-Road ARB Compressor & Air Coupler Switch Bracket
ARB Air Hose Coupler (JIC-04 37 Degree Flare Fitting)
ARB Air Hose Coupler Dust Cap
ARB Reinforced Hose JIC-04 0.5m
ARB Reinforced Hose JIC-04 0.3m
ARB Adapter 1/8 BSP (M) JIC-04 (M), 2 Pack
ARB Adapter 1/4 NPT(M) JIC-04(M), 2 Pack - Only 1 required
ARB Air Line Adapter Fitting 45 Elbow, 2 Pack - Only 1 required
Please note, due to the configuration of the ports on the ARB regulator I was unable to have the input and output hoses on the same side, so the layout is a bit more spread out than I would have preferred. Also, the spot where I mounted the regulator needed to be twisted a bit so the pressure sensor would clear the coupler. Finally, the screw I used for the regulator mount was a bit too long, so I used four washers to take up the extra space.
Initially I planned on using the supplied ARB switch, but I decided to forgo that idea because using the upfitter switches made for a cleaner install.
*** It looks like you're using a 90* fitting on the compressor, but it is not in your parts list. I ended up using the second 45* connector and one of the extra adapters. ***
I added a Weather Pack connector to the Air Pressure Control power lead near the other Compressor connectors to aid in removal of the system. I wrapped the Pressure Control power lead and Compressor trigger harness together to make a single harness. I used a Weather Pack connector on the Bronco Aux Switch lead (doubling the Compressor trigger and Pressure Control hot to 1 single Weather Pack. I routed the 2 harnesses along an existing harness across the firewall.
I velcro-ed the Pressure Control computer to the top of the @4x4TruckLEDs.com mount.
I used this cloth fabric tape to make my harness for Pressure Control hot and Compressor trigger.
https://www.amazon.com/gp/product/B01LYZDN2X/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I used this Weather Pack kit for connections.
https://www.amazon.com/gp/product/B01CN99TCA/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
And some self adjusting wire strippers to save some aggravation.
https://www.amazon.com/gp/product/B000OQ21CA/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
