- Thread starter
- #1
Posting to see if anyone figured out a permanent solution, I have an issue with speakers cutting out randomly. Random outages includes all audio via carplay, radio and even parking sensor alerts/warnings. Only sound that will come through is turn signal. Issues started recently, sometime in November. No rhyme or reason as to why or when, but seems to occur at engine start or when auto start/stop engages. I read somewhere that Bronco system may shut off "non vital" functions if battery voltage too low, but my battery appears to be healthy. As I mentioned, I pulled (and replaced) three fuses to audio control module, sync module and amplifier. Seems to help for a period of time then back to square one. Turning off ignition and letting Bronco sit also helps (most of the time), but it is also a short-term solution as issue continues to occur. Audio issues getting worse as I have now had audio cut off multiple times while chauffeuring kids or running errands and making multiple stops.
I will caveat that in March '24 I had a higher end after market system professionally installed, but my audio guy said he had worked on numerous Broncos with no issues, and said Ford wont touch system under warranty unless audio guy can pinpoint issue. Frustrating that now I am have to sit in silence while I listen to the road noise from my 37s, windows rattling and wind whistling through the hardtop. Joking aside, love my Bronco and it is not perfect, but this audio issue is beyond frustrating.
