Thank you!! Saved me a trip to the dealer and resolved the back window issue.Do the reset/relearn procedure. Vehicle on, roll down window, hold down for 5 seconds, roll window up, hold for 5 seconds.
No need to comment, you don't add to helping resolve this issue.Never had a problem... works as they are suppose to...
Sorry did not know that I was not allowed to commit....No need to comment, you don't add to helping resolve this issue.
Same problem. Were you able to fix?Yes, having this issue with a 2 door First Edition. Happens both driver and passenger sides, though not always at the same time. Window goes up to close, then "bounces back" and returns to half open position. Always the same half open position. Happens like 40 to 50% of the time you go to close a window. Happens whether you raise "manually" or whether you go past detente to fully close. I have reports of this happening in BMWs, VWs of an older vintage so quite probably a common sensor that many mfrs use. Needs to be fixed, its a real problem, sometimes it happens repeatedly and you can't get the windows to close.
