Automatic windows issues
DarkHorseDarling
Aaron
Dallas, TX
'22 Bronco Badlands, '17 Toyota Highlander
I’m having issues as well with the auto up/down feature with our ‘22 Badlands (lux). Front passenger window stops half way. :(
bobogto
Chicago
M5
I know technically it is an issue, but in reality it is not. Windows have a switch/sensor that will shut down the closing if it senses back force- think old mafia movies with the guys head stuck in the window. It either could be a faulty switch or most likely it gets pushed back by the windows pushing on the seals too much- probably not aligned properly. Or something else exerting force on the window.
Either way I don't think this is such a big deal. I've had it happen once. And your only problem is that you either have to press the window switch again or just hold it.
To be fair I have a 2001 BMW that has the same feature and I've never had a single issue with them, but again... This is a cheap Ford. Don't expect miracles.
jorgem31
Jorge
Tampa
So, has anyone gotten this fixed?
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
Anyone checked the area the window rides up? anything sticky?
UtahLars
Laurent
‘21 Ford Bronco First Edition. ‘21 Audi RS6 Avan
Yes, having this issue with a 2 door First Edition. Happens both driver and passenger sides, though not always at the same time. Window goes up to close, then "bounces back" and returns to half open position. Always the same half open position. Happens like 40 to 50% of the time you go to close a window. Happens whether you raise "manually" or whether you go past detente to fully close. I have reports of this happening in BMWs, VWs of an older vintage so quite probably a common sensor that many mfrs use. Needs to be fixed, its a real problem, sometimes it happens repeatedly and you can't get the windows to close.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey there! I can look into your Bronco’s window concerns on my end if you’d like. Will you send us a private message with your VIN and dealership info?
blue182
Tom
dmv
AMB BD
Can you keep us posted on how this gets resolved? I'm having the same issue. It mostly happens on the passenger side. My windows all go all the way up then one drops back down or one will stop half way up.
rayhil67
Ray
Douglassville pa
22 2dr Bronco, 06 hummer H3, 01 SuperDuty F250
I have learned to live with this as it is a feature not a bug! had dealer do reset, I've done reset several times, passenger side refuses to comply.. Solution when u want to put up windows reach over and unlatch door, this will put the window up to the "open door Height' then reach over and close door and it will inch up to closed Height
blue182
Tom
dmv
AMB BD
When I picked my bronco up the front passenger window was misaligned (the glass was pressing against the soft top). I performed the the window reset before I even drove the bronco. My windows drop half way down. I've walked out a few times and noticed one of my rear windows was open half way. They initial all go up then one will drop back down to half way.
edernest
Ed
2022 Bronco Sasquatch
I've got the same issue with my front passenger window, sometimes come back to find it was about 90% open after hitting the automatic close on all four of them. I've tried the window reset procedure but that hasn't fixed it. Has anyone reported this issue to their dealer and if so were they able to help at all?
blue182
Tom
dmv
AMB BD
Here’s a video of the issue I’m having.
Ford Motor Company
Dearborn
Hi Ed. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Kygolfer
Kentucky
Jeep Wrangler
Yep. My front passenger side goes up 75% then I have to toggle it up the rest of the way. Others go all the way up.
UtahLars
Laurent
I will if there's anything worth saying. So far no solution on offer and no prospect.
rayhil67
Ray
Douglassville pa
So I have had the passenger window indexing / coming back down issue since July. Two weeks ago I had dealership do second oil change and I informed of the issue again, this time they new what to do, they ended up pulling the door apart and adjusting and tightening the "window track system" and so far this seems to be working... I remember the old saying "At Ford Quality is Job 1" not so much anymore
