Aux Switches - Whatcha got wired up?
GroovyGeek
Boyan
'23 Bronco BD
2 led bar on bumper
3 ditch lites omag the accessory points
6 el cheapo front facing camera
Don't see myself using the remaining 3 positions
smonroe11
Stephen
Dallas
Chevrolet Tahoe
Aux 1: M and R 40in Light Bar - White
Ford Bronco Aux Switches - Whatcha got wired up? IMG_3066
Aux 2: M and R 40in Light Bar - Amber DRL
Ford Bronco Aux Switches - Whatcha got wired up? IMG_3064
Aux 3: Kicker 6 1/2 inch LED 45KM654L in SSV Pods
Ford Bronco Aux Switches - Whatcha got wired up? IMG_3063
Aux 4: 4 Inch Rigid 360 Series with Amber covers
Aux 5: Rock lights and also hooked into Interior/Puddle lights. Come on when doors open or unlocked.
Ford Bronco Aux Switches - Whatcha got wired up? IMG_3059
Aux 6: KC 2" C-Series C2 LED - 20W Flood Beam also hooked into Reverse Light
Ford Bronco Aux Switches - Whatcha got wired up? IMG_3068
NoloBronco
Nolensville Tn
2022 Bronco Badlands SAS
Cool, do u know the best place to do that?
And what the volts & amps are of the markers so I can check if my LEDs are compatible
Looks like it was green/orange for the parking lights that I tapped into.
Ford Bronco Aux Switches - Whatcha got wired up? IMG_7559
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
I'm sure I'll change this up a bit later on but currently mine is:
1. rear chase bar
2. front light bar
3. ditch lights
4, 5 and 6 currently work different functions of my fog lights (off-road, back light only, fogs only)
Can you share a photo of your rear chase lights/bar?
vrtical
Doug
GSMNP, TN
Fords
Ford stole #1, 2 and 3 are empty for now (higher amp), 4 is ditch lights, 5 is front bumper floods, 6 is empty but will be for rear chase/flood light.
Ford Bronco Aux Switches - Whatcha got wired up? flood_lights
da_jokker
Jeep Wrangler JKUR
Switch #3 wired to a battery isolator for my winch.... that's all I got so far.
The fact that the axillary switches lose power the moment you shut the Bronco down really throws a lot of the advantages out the window.
Luckylat
RI
1999 Expedition, 2013 VW Wagon, 2023 Wildtrak
1. DD SS3 Pro Ditch Lights (Yellow backlit)
2. DD SS3 Max White Combo (Yellow backlit)
3. DD SS3 Pro Yellow Fog (Yellow backlit)
4. DD SS2 Pro white Fog (Yellow backlit)
5. Yellow backlight switch (for 1-4)
6. Rear 3" LED Pods -Back up lights (Amazon
Ford Bronco Aux Switches - Whatcha got wired up? IMG_1890
Ford Bronco Aux Switches - Whatcha got wired up? JS Bronco_Redacted Plate
Donkey
Tijuana
totalled
Correct me if Iā€™m wrong as I donā€™t have my bronco yet, but isnā€™t the first switch the highest amp? Why? Why put what would inevitably and hopefully be the least used in the closest switch? Is there enough slack to reverse 1 and 6? Iā€™d rather use it for suicidal deer lights.
BeerRunner
LUKE
Blythewood, SC
2023 Bronco
I really like this idea, donā€™t even need to use a aux switch for. I think this might have to be my next project
