Really like where you placed it. Just received my switches and plan to install soon never done anything like it before! So kinda nervous lolHere are some pictures of the install I did last weekend on mine. On the bracket that holds the electronics box I needed to cut off the tabs I marked in one of the photos and drill a hole a little closer to the bracket to attach it to the battery hold down bolt. The circuit breaker is bolted to the battery tray below the Electrical box bracket on one of the square holes. The wiring was ran into the cabin through where the clutch would pass through the firewall and ran the cable up through the A pillar. The switch panel was held in place with 3m tape so no holes had to be drilled. The fuse tap provided is the wrong size so just go to auto zone and pick up the correct one.
