Backup Camera issue!
RenJayy
Rene
Southern California
2023 Badlands Sasquatch
Hey guys, picked up my Bronco from my dealer today. However the backup Camera on my Lux Badlands seems like it's not as clear as it should be. I'm including a picture of my badlands and of a Wildtrak . Is there a recall or some sort of fix?
Ford Bronco Backup Camera issue! IMG_9421
Ford Bronco Backup Camera issue! IMG_9422
BigHoof
PA
Ram 2500
Based on the pictures, both still have the clear protective film on the screen. Clearly says "This film is to be removed before usage."
Lowcountry Bronco
William
South Carolina Lowcountry
Ford Bronco Backup Camera issue! download
BigHoof
PA
Ram 2500
You can see the film lifting in the corners on the lower picture which is the Badlands.
Might be the rim or tire I am seeing? Regardless, the film needs to come off.
RenJayy
Rene
Southern California
What a helpful bunch of individuals...
Update: something is wrong
Ford Bronco Backup Camera issue! IMG_9426
spuddy59
Chase
Lubbock, TX
2023 Bronco
Yeah, looks like your camera is dark. You might want to have a dealer check that out since you solved the “This film is to be removed before usage" issue.
RenJayy
Rene
Southern California
Actually it's still on
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
99 7.3 F350, 22 7.3 F350,25 2.7 BADLANDS SAS
Yeah,We are having similar issues..Ford looking into it now..
Ford Bronco Backup Camera issue! Resized_20230626_054526
To be continued..
Keerplunk
Izzy
Burbank CA
2007 Jeep JKU, 2022 Cyber Orange 4Dr Bronco
The rear view cameras suck it is just a fact the Night shot seems your reverse lights are not on and you are parked in a garage (Are you trolling with this thread?) but not removing that film only makes it worse, if you think people were joking about removing the film they were not, and if you do not want to remove the film then maybe don't bother to ask what the issue is because you do not seem to want to listen to advice given.
BigHoof
PA
Ram 2500
Exactly. The initial issue was that the view was not clear. Most likely caused by the film. Nothing mentioned about it being blank.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello, Rene! Send us a private message with your VIN and the name and location of your local Ford dealer.
I’d be happy to see what I can do to assist with this concern. Thanks!
RandyMc
Randy
TN
I am having a similar problem. Only happened once so far, but the camera was totally black. Interested to see if others have seen this.
