Badlands with 7MT (Best options for 35" tires)
Gomezstx
bronco
Changed my plans and now have a build scheduled. Advise would be appreciated on solid options to lift and level for 35" tires (Badlands with 7MT)
- Prefer options to retain the OME shocks
- spacer or perch collar? or combination of both
- Is there a replacement spring option like Eibach (which I purchased for what was going to be a sasquatch order and now is a none sasquatch order)
I don't plan on above 35" tires. I will add the performance tune to get torque and horsepower bumped up. Will add use Icon rebound pro wheels and goodyear sasquatch tires (so my weight is in check)
EDIT 1/26/23: The feedback I have received is the badlands Bilstein non-sasquatch strut is the same as the sasquatch strut with the difference being; the perch collar on the sasquatch is set at a different elevation 0.43" higher. The bump stop on the sasquatch is also 0.4" taller to prevent the 35" tire from contacting the wheel well at full compression. Conclusion that I make is the badlands suspension none-sasquatch can be converted to sasquatch with those two simple modification (perch collars 0.43" minimum plus add 0.4" bump stop extension)
Karl_in_Chicago
Karl
Chicago
If you are starting with a stock Badlands I really don't think you need any lifting to get from 33" to 35".
Tricky Dick
Dick
PNW
www.TD-Distributing.com
You don't *need* any lift for 35s if you keep the wheel offset reasonable. An extra inch up front looks less stuffed and better though IMO.
Gomezstx
bronco
Gomezstx
bronco
Zero offset on the Icon rebound.
Bikeric
Tulsa
2022 Badlands on 37's, 2003 V8 4Runner on 35's
YOU CAN use the Eibach springs on your Non-SAS Badlands with the piggyback Bilstein shocks. The only difference in the shocks is 0.43" of body, but they have the same travel and same spring perches. The Eibach springs will have a higher spring rate to provide you with the lift over the stock softer springs. You can also install the Zone 1" front level kit while you have the shocks out.
Gomezstx
bronco
If this is correct about the Eibach (I have those purchased and I’m position when my original plan was Sasquatch build). I see that the part numbers are different for the none Sasquatch bilstiens. But I am not yet understanding if these Eibach springs are will fit. Based on your feedback I do need to get that validatyed with Eibach technical support (My next step).
So is it your understanding that these two shock are the same (and the Eibach spring is compatible with either)
Thanks
Bikeric
Tulsa
What I have found is that the aftermarket refers to the yellow Bilstein shocks as "Sasquatch". As far as the aftermarket is concerned every Badlands is a Sasquatch because they have the Bilstein shocks. The Non-Sas Badlands shocks are just a "Special" version with 0.43" less body length/height. The link below is LONG but well worth a read through. Your Eibach springs will work just fine with what you have.
https://www.bronco6g.com/forum/thre...ide-lift-heights-with-wheel-tire-sizes.17719/
Edit: I've got a non-Sas Badlands and I WISH I would have had the Eibach springs ready to go with. I did my lift with 2.25"fr/1.25"rear perch collars and the Zone 1" front level kit. (I'm running a winch and didn't want the forward rake).
Gomezstx
bronco
You all are great. Really appretiate the knowledge shared
BenBronco
Alabama
2011 F-150 and 2020 F-150
Gomezstx
bronco
I updated my research. A taller bump stop is required on the badlands none-sasquatch strut or risk of wheel well contact is possible with the OEM sasquatch tire/wheel package. The sasquatch strut has the perch collar set at a higher elevation 0.43". So two those things required to get to sasquatch spec
Gomezstx
bronco
I updated my post with my findings. Looks like a bump stop extension should be installed if doing 35s (sasquatch OEM wheels / tires). And the saquatch lift is achieved with preload from the factory by setting the perch at a different elevation
Tricky Dick
Dick
PNW
I never needed a bump stop extension and I've worked the suspension hard.
Gomezstx
bronco
Eibach has a badlands none sasquatch at their shop today for testing. I am waiting for their final results. The feedback I have so far is the difference between the badlands none sasquatch and sasquatch shocks are the perch collar on sasquatch is set at a higher elevation which is how the additional 0.43 inch lift is established. The bump stops are also longer by 0.4 inches so that the 35" does not make contact with wheel well at full compression. The Eibach springs may just be the ticket (along with bump stop extended) to a good lift height for 35" and keeping everything inside of the operating parameters Ford intended
