Beadlock Wheels - Legal or Illegal and the DOT
1975U15
2019 F-350 SD, 1975 Bronco
  • Like
Reactions: JPG
BlueBronco
DFW
It is not necessarily beadlock wheels that are illegal in many states, it is usually multi-piece construction wheel that are illegal. Beadlock wheels just happen to fall into that category.
Somebody, somewhere along the way must have decided that multi-piece must also mean multi-points of failure. Not sure I agree but also not sure I trust the general public to properly check and maintain torque spec on all those bolts.
swooshdave
Portland, Oregon
Mustang
They're on my list as well, but all those O-rings have me nervous.
The nice thing about the Method Bead Grip, is that they grip on the front and the rear of the wheel.
If o-rings have you nervous...
Tech Tim
Tim
Wet Side of WA
Jeep JKU
Snip.......
Personally am considering the Hutchinson Inc Rock Monster Wheels, however when I reached out to them last month they stated late summer 2022 availability for the Bronco.
The Toyota Hutchinsons will fit the Bronco. The backspacing is a little different, but would work.
GToddC5
Todd
South Jersey
www.bronco6g.com
The introduction of 80 new potential leak points with easy access to the hardware by idiots, deserves to be considered when there's an option that does not. Don't be surprised if we find out that the o-rings are recommended to be replaced any time the bolts are removed. Galvanic corrosion should also be considered if the hardware and wheel are dissimilar materials.
I will also be considering a weight comparison. Icon beefed up the material on the spokes, on top of the added weight of the hardware, so they may be heavier than the Method Bead Grips.
Merc4x4
steve
NJ
Dusty at ICON
Dusty
Riverside, CA
2021 Bronco Base 2-Door
1. Our standard Rebound (non-pro, non InnerLock) weigh 27 lbs. Same size Rebound Pro weighs 28 lbs.
2. Every aluminum beadlock wheel has dissimilar metals touching, whether it's the threaded inserts or the bolts themselves. I've yet to see a beadlock with aluminum bolts (or aluminum lug nuts, for that matter).
3. You should never have to remove the InnerLock pins unless you are dismounting the tire. They do not see constant stressing, loading and unloading, the way a normal beadlock bolt does. And the o-rings, along with the design of the machined bosses they seat into, are directly lifted from hydraulic applications, which see several orders of magnitude higher psi, higher heat cycles, etc., than they will ever see in this application. By the way, what is the tire itself, if not one giant o-ring with vastly more sealing surface area than the InnerLock o-rings?
4. Not too many idiots walking around with a 12-point 7/16" socket in their pocket but if they really want to let the air out a knife is quicker.
Any other questions? :)
GToddC5
Todd
South Jersey
www.bronco6g.com
1. Thank you - Your wheels are 2-3 pounds heavier, each.
2. Normal bead lock hardware does not breach the inside of the tire cavity, nor do they have o-rings. On your design - as the corrosion "grows" over time, it can damage any threaded and o-ring type of seal. Hydraulics leak all the time, I would not uses that as a good selling point. 80 new rubber seals are certainly something people should take into consideration, regardless of how great you think your design is.
3. Air pressure whether high or low, is helping keep the giant o-ring (tire) sealed. Air pressure is not keeping the smaller o-rings sealed.
4. So you're saying there's a chance
Any other answers? ;)
Keep in mind, this is an informative thread not biased toward any one vendor - I'm not bashing your product - It's a fine option, but likely not my option.
Dusty at ICON
Dusty
Riverside, CA
Wasn't taken as bashing, this is a good discussion! We simply don't share your concerns, at least not to the level of concern that you have. But to raise them is valid.
