- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
If you are in search of quality aftermarket Exhaust Upgrades for the 2021-2022 Ford Bronco, then you really need to check out what AWE Exhausts has been up to. They have been working nonstop to design and engineer a new line of cat-back exhaust systems that are perfectly contoured and fit for this vehicle. The AWE 0FG exhausts are modular configured cat-backs that are the new standard for versatility. They are designed and engineered in house at AWE in the USA and are meant to be the exhaust built for any terrain. Each AWE 0FG exhaust features the trademarked Bashguard, which is the hallmark feature that makes these cat-backs so resilient off-road. This feature is a .125" thick reinforced stainless steel ring that replaces the rear axle portion of the exhaust system. It offers upgraded protection from damage caused by dirt and debris. If you are an experienced off-road driver, you know that it can get rough out there for the undercarriage when you a really ripping it up and getting after it. The AWE 0FG exhaust sits high and tight while staying protected with this unique exhaust system feature. There are a few different variations of this cat-back exhaust that you should check out with different tips and number of exits.
2021-2022 Bronco AWE 0FG Cat-Back w/ No Tips
For the most stealthy and hidden setup of this line of exhaust systems, you should consider the AWE 0FG Cat-Back with No Tips. In this version, you will not get the aesthetic edge of incorporating a tip, but you will still get the fantastic functionality of this cat-back design. You will still benefit from the deep, aggressive sounds with minimal drone that this exhaust creates. Without powerful and more attractive sounds, what use is it in getting an aftermarket exhaust. That is like drinking decaf coffee. Despite the aggressive sounds of this cat-back, it is not overly obnoxious for the times when you have to hit the public streets. It can be embarrassing to have an extra loud exhaust among the common folk. They will never understand the thrill of a sexy sounding cat-back, but they will nothing to make fun of you about with the AWE 0FG exhaust. Not only is it the exhaust for every terrain, but it is the exhaust for every situation.
2021-2022 Bronco AWE 0FG Cat-Back w/ Single Chrome Silver or Diamond Black Tip
If the no tip exhaust is not your style, you might want to consider the AWE 0FG Cat-Back with Single Chrome Silver Tip or AWE 0FG Cat-Back with Single Diamond Black Tip. These single tips are 5" wide, straight-cut, and double-walled. You have the choice of either a chrome silver or diamond black finish on them. They not only add an extra aesthetic edge with their stylish finish options, but they provide more exhaust flow with an additional 2" of exit space from the no tip version. With this kit specifically, you will get better departure angles clearances over the single tip and dual tip versions. When you install any of these AWE 0FG cat-back exhaust models, you will be happy to know that there is no additional cutting or drilling needed to complete the installation. The bespoke mounting bracket allows this exhaust system to be installed with or without a tip and eliminates any interference with the rear bumper. The rest of the exhaust system also sits high and tight to the underbody and is reinforced with locking collars that replace the factory hangers. This offers upgraded support that prevents movement to keep everything safe and functioning properly. Not that this exhaust system even needs the extra protection because it is constructed of a super strong CNC mandrel-bent, US-sourced .065" thick walled stainless steel tubing that is built to withstand any degree of off-road use and abuse.
2021-2022 Bronco AWE 0FG Cat-Back w/ Dual Chrome Silver or Diamond Black Tips
If you want to go the distance and maximize your exhaust flow, then the final option you have is the AWE 0FG Cat-Back with Dual Chrome Silver Tips or AWE 0FG Cat-Back with Dual Diamond Black Tips. These dual tips are 4.5" wide, slash-cut, and double walled. You have the choice of either a chrome silver or diamond black finish on them. There is almost double the amount of exhaust flow for the most efficient exhaust in the AWE 0FG lineup. Your engine will be thanking you for letting it reach its full potential and stay healthy while it does. The rest of this cat-back is made with a straight-through design that continues the focus on efficiency for maximizing performance and tone. All of these AWE 0FG cat-back exhaust models are applicable with both 2-Door and 4-Door 2021-2022 Ford Bronco models. They come with a perfect fit guarantee that ensures no matter which version of the this vehicle you have, you will get the highest performing cat-back with contours perfectly fit to the existing features of the 2021-2022 Ford Bronco.
Fits Any Ford Bronco Engine Model
So many options and configurations to choose from, what do you do? Luckily, choosing any of these AWE 0FG cat-back exhaust systems will make an exponentially better off-road build and is guaranteed to leave you satisfied. If these cat-backs are any indication, then it really is an exciting time for new 2021-2022 Ford Bronco aftermarket products. If you were reading this and worrying if any of these cat-backs would even be compatible with your 2021-2022 Ford Bronco, then you can relax. All of the AWE 0FG cat-back exhaust systems fit any Ford Bronco engine model. Whether you have a 2.3L or 2.7L EcoBoost, you will be able to cash in on the major benefits that having an aftermarket exhaust system gives you. However, these cat-backs will not fit Ford Bronco Sport models.
Categories Mentioned:
Products Mentioned:
Products Mentioned:
