Black Diamond Bronco Thread
flatlander40
Why hasn't Ford shared some non CGI pictures from all sides of the Black Diamond? It would be nice to see how the 32's look inside those wheel wells.
there are a few side shots around of the Big Bend and the tire sizes are similar. Actually, if I have this correct, the Big Bend tire is slightly taller than the Black Diamond.
Ford Bronco Black Diamond Bronco Thread 1603058822758
Chrism81
chris
connecticut
Mazda
But you can't get the Mid package on the Base, and that is my wife's one condition, so BD it is.
True. I'm not interested in the packages. Nothing with those really make me want it.
  • Like
Reactions: LMB
Lou
Tn
Chevy
Question:
When any of you reversed the BD do you remember what the base price was? For some reason i thought it was like 33k. But i have been looking at all of them and i just may have mixed numbers up.
Ty for any info
BroncoJay
Iowa
Tacoma
Question:
Ty for any info
36k for the 2 door when I reserved in July 22
Stitches1974
SW Florida
2019 Dodge Challenger Scat Pack
  • Like
Reactions: Lou
Kenny
Kenny
Alabama
2016 Silverado Z71
Question:
Ty for any info
Think it’s just over $36k.
  • Like
Reactions: Lou
FishKzor
Tom
Phoenix, AZ
2009 Mustang
I reserved the Base 4-door on July 15th, but I full intend to switch over to the Black Diamond 4-door Sasquatch (pending any sort of surprises in the B&P). The marine-grade vinyl is nice feature to have out in the AZ heat, and access to both Cactus Gray and the mid-package is too much to pass up, not to mention the modular bumper. (My two sense).
Also, I'm curious to see if any options that are only available on higher trims will be available a la carte.
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
Well, the Mid has a lot of the basic stuff I want in any vehicle. don't need High or Lux. The Base comes with nothing except push button start, if you're going to Squatch it and use it as a rock crawler then that's the way to go.
Mopar2Bronco2021
Houston
2018 Dodge Charger RT 5.7L
I wouldn’t say the Base comes with nothing. You get an 8” screen with apple/android CarPlay. The digital trail maps from Ford is on the Base I believe too. So there’s a little bit of spice on the Base trim. Just enough for me at least.
LMB
Lou
MN
2000 F250 Superduty 2016 Jeep Wrangler 2door
Do you know if the BD 2door (hardtop) has rear window defroster as standard equipment? Base has power windows and locks standard too.
I do not want 90% of the stuff in mid package either. I wish there was a key for starting the Bronco if you do not buy the mid package. Using a fob to get in and then putting the fob in my pocket to push a button to start seems silly to me. If I need a fob to get it I would prefer to put a key in and start the Bronco. The key can stay in the ignition until I leave and lock the doors again.
  • Like
Reactions: JAM
cdoublev
Charlie
Massachusetts
Mini Countryman
If I want, I can manually set temp in my car that has auto climate
