Blow off valve phhh sound
TheGhost
Central TX
2021 Bronco Badlands, 2009 Mazda RX-8
The ECU is speed density, so venting boost to atmosphere has zero effect on mileage, nor will it affect idle/throw a code etc.
Having said that..operating a bypass valve in VTA on a truck baffles me (makes more sense for a boosted sports car owned by Vin Diesel) but to each his own...
Ryan
2.7TTBroncoPlumb3r
2021 wildtrak Bronco
My friend installed a turbo smart dual port BOV on his 2.7 badlands. He mentioned to me that the was concerned about a faint engine knock at idle after the vehicle was warmed up. This was a couple weeks after install. 2 months later he said it was bothering him. I told him to take it off and put the stock one back on and take it for a drive. After he installed the factory one, the knock sound was gone.
Im not so sure that the dual port version performs as advertised so that the sound and plant back needs are met. I plan on a full plumb back BOV once my hot/cold charge piping get here. Already have the whipped intercooler on it. Then I’ll get the ford tune or look into custom tune.
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
As a kid I use to attach playing cards to the fork on my bicycle………didn’t help or hurt performance but I thought it sounded cool 😎
Techun
Pa
BD, 2.7, MIC, 4dr
No. That's not how turbos work.
What do you mean? A turbo can absolutely make boost for extended periods of time. A 2.3 badlands sasquatch or manual trim could be in positive pressure on the highway indefinitely.
GI_Jo_Nathan
Jonathan
I'm saying whether you're in boost or vacuum will have nothing to do with the trim of the Bronco. It's strictly the load your putting on it.
Billnchristy
William
Georgia
2022 Bmw m440i gc,2022 BD 2dr, 1966 mustang
Simple way to tell, put your boost gage on. You are on boost when you're on throttle. Sure, if you're going down the highway with constant pressure on the accelerator you may be making .2-1psi constantly but we're talking about 7+psi to make whooshy noises anyway. If you log it, you make boost for very short periods of time.
Frankie945
Frank
Louisville KY
Q50
Someone needs to get this and let us know if it really sounds like this on the street and not just on the Dyno. That 2jz blow off sound. 😊
Techun
Pa
BD, 2.7, MIC, 4dr
Oh, yeah of course. I'm just saying certain trims/configurations will be under higher load in top gear.
A manual base and a manual badlands will vary in effective gearing, weight, aero, etc.
broadicustomworks
Hanging Rock, North Carolina
It does.
fdchief
Ohio
2023 BadSquatch, 1995 F250, 2018 Rebel R2
so i totally just bought one simply because hearing the youtube video took me back about 20 years when i built my first "tuner car"..... which was a srt4..... ill prolly run it for shiggles then take it off, but for nostalgia factor alone i had to buy it.
LethalPerformance
Jared
South Florida
www.lethalperformance.com
We initially installed the UPR BOV spacer which worked great. It still utilizes the stock recirculating BOV but allows the air to be vented to atmosphere giving it that PSSSSHHHHH sound.
Eventually once we tuned the vehicle with the Whipple calibration and were making more boost than stock we installed the Turbosmart dual port valve which also worked great for us.
Both are very easy to install and had no issues whatsoever.
For me if I were staying at stock boost levels I feel the BOV spacer is a no brainer. For those that tune their vehicles going with a top tier BOV from Turbosmart is what I'd recommend.
Let us know if there's anything we can help you guys with.
