What tint did you use and where did you buy it from? That’s exactly the look i wantYes they can be wired to upfitters very easily.
I tinted mine before installation
I sprayed the lights with VHT night shade then finalize with the VHT clear coatWhat tint did you use and where did you buy it from? That’s exactly the look i want
Very nice. Love the idea of the tint. We’ll done.Yes they can be wired to upfitters very easily.
Same here. Not used but there. I used #22 to piggyback on because it turned on and off with ignition.Anyone know what fuse 21 is for? My FE has a fuse in it and is hot. The fuse diagrams I find say its not used. Some posters claim no “guts”
Yeah me also, that will be a pass for me.Very disappointed there are not 3 lights
Probably a dumb question- did you have to remove the safari bar to install these?
LOVE the way these turned out. Also, #21 fuse didn’t have internal connection components so we ended up using fuse # 26 together and it worked perfectly.
I have zero mechanical inclination so it didn’t take me 15 minutes, like it mentions, it took me just under 3 hours and thank God my neighbor could understand to use fuse #26 Instead 21.
The video on YouTube was super helpful..so is printing the instructions beforehand.
Not a dumb question at all. Yes you have to remove the Safari barProbably a dumb question- did you have to remove the safari bar to install these?
Please send us an email at laura@broncoledshop! It sounds like the wiring may be pinched on that bulb, we can help get it sorted quickly for you!Installed mine last night to the ignition fuse but I'm having a problem as only 2 of the 3 LED's light up. The drivers side will not illuminate- any ideas?
We design our LED kits to sit flush with the for an OEM look and installation. The Black Diamond/Base/etc kits have a plate right behind the grille in the center slot. Because of that we've opted to design our kit with 2 LEDs only, so the installation is flush with the grille and no LEDs are sticking out beyond the grille itself.Yes exactly. But at this point I’m very good at waiting for what I want. Lmao
If you decide to offer a 3 light for the Black Diamond I would buy itWe design our LED kits to sit flush with the for an OEM look and installation. The Black Diamond/Base/etc kits have a plate right behind the grille in the center slot. Because of that we've opted to design our kit with 2 LEDs only, so the installation is flush with the grille and no LEDs are sticking out beyond the grille itself.
