6000 # and over is considered by the IRS to be Heavy equipment and has over time been given very generous business tax deductions. Some manufacturers have run into trouble labeling vehicles 6000 #'s when they were not. Thinking Ford maybe trying to stay clear of this.My take/estimations - Ford needs to cap GVWR at 6000 to stay in the class.
if a 2.7L 4 dr loaded OBX is say 5,000 lbs wet, and a 2.7L 4 dr loaded BL is say 5,200 lbs wet, that leaves you with a 1000 lb payload vs 800 lb.
if you do some digging on how you typically calc payload and ran the math...for a family of four, with a full cargo hold on a road trip... let’s say 200 lb dad, 150 lb mom, and two 100 lb teenagers (give or take smaller kids or add dog) plus 50 lb luggage each, 100 lb misc. that’s 850 lbs. add loaded cargo box at 150 lbs for kids random stuff (I know max cargo box weight is capped off slightly lower per ford, but forget) and you’re at 1,000 lb total payload.
looking at SUVs most safely exceed payload of 1,000 lbs falling around 1,300-1,500 lbs.
So if I’m thinking about this right, and the roof rack is the biggest tell on what Ford wants you to strap on the roof, the OBX 2.7 does allow for the rack, and the BL 2.7 does not. That seems to be about the difference of the added weight of a loaded cargo box. And roughly the difference of 800 vs 1000 lb payload.
So if you plan on occasionally using this like an explorer for family road trips, the badlands 2.7 may not be the trim for you.
sure, the GVWR is an arbitrary number, but if we do find out that we can’t add 1,000 payload to a 2.7 BL I can’t bring myself to get that trim just based on my families safety. If you google other guys asking if it’s okay to exceed GVWR the responses are not very comforting. Could it handle more? Probably. Is Ford capping GVWR to compete with wrangler? Probably. But to strap my family into a tall roofless truck with 1,000 lbs of stuff for a long trip and go against the numbers is not something I’d be comfortable doing.
before you bash me and say well go get an explorer then! Fine. But all Im saying is if you want this truck to serve double duty, for off roading or over landing plus family trips, we may find out we need to be more selective over our build. This could rule out the 2.7 sas 4 dr and potentially the 2.7 BL 4 dr. There’s a reason Ford says there’s a trim for everyone but it sounds like we should be prepared to find out a more extreme build with bigger tires and a lift won’t have enough payload to serve double duty.
That’s my take. So until we know the GVWR numbers I can’t bring myself to getting the BL. I’d rather have the peace of mind I’ve a different build/trim where I pick up more payload.
but let’s allow the numbers to be released and do the talking...
