- #76
It’s going to totally depend on how many amps you’re pulling. What are the tech specs on your lights?Quick question on Aux switch for Baja Squadron Rs. I am thinking Aux 2. Any other recommendations/
Appears they run 2.9 amps per light so really any of the 6 switches would work as the lowest rating is 10 amps.Quick question on Aux switch for Baja Squadron Rs. I am thinking Aux 2. Any other recommendations/
Many Thanks.Appears they run 2.9 amps per light so really any of the 6 switches would work as the lowest rating is 10 amps.
Those are very cool!I asked the same question a while ago. This seemed outstanding for low profile.
https://blumak3d.com/products/ditch-light-housings-with-baja-designs-s2-sport-leds-21-bronco
Is the color temperature 5000k or 6000k? Do you have night time output shots?The Ford Performance Rigid ditch lights worked the best for my fitment use case. You can see I had to go with the inner bolts instead of the outer bolts but thankfully that didn’t end up being a distraction or eye sore from the drivers seat. I think if you could install them as intended on the outer bolts, the A-pillars would pretty well disguise them entirely. But as you can obviously tell I was dealing with my GMRS antenna. And I’ll just remove the FM/AM antenna when off-roading to get it out of the way. They are incredibly bright. I tested them on some back roads in northern Georgia over Christmas and they are exactly what I need. Unfortunately they are so helpful that it exposed how weak our headlights are and now I’m contemplating how I can add some forward lighting. Not sure I want a light bar. Sorry for the not great pics, but I randomly thought of this thread while parked on the side of the street today.
I like my Diode Dynamics SS3 Pro Combos!I've been happy with my Diode Dynamics SS3's.
I should have some video from Allegheny Discovery Route. I didn’t run the cameras a ton after dark but I’ll see if I can find something.Is the color temperature 5000k or 6000k? Do you have night time output shots?
What bracket is that for your ditch lightsMorimoto 4 bangers! Very pleased with these. Just make sure to get the HXB led chips. I got the wide beam pattern and they Still shine almost as far as my highbeams. Not to mentions to can see way off to the sides as well.
https://www.morimotohid.com/Morimoto-4Banger-LED-A-Pillar-System-Ford-Bronco-2021?quantity=1What bracket is that for your ditch lights
