- Karl
- Nov 26, 2021
- 16
- 347
- 641
- Central Fl
- BMW M2 Competition
- Badlands
OP, I towed a 30 ft fifth wheel camper that weighed about 10k lbs for 100,000 miles all over USA w/ 2500 ext cab Chevy 2500hd w/ duramax and allison trans. Figuring out if you're towing safely and legally is actually somewhat complicated. And requires going to a truck stop, pulling your entire rig onto scale so it will weigh each axle. Then you pull off, drop the trailer, and back to scale w/ tow vehicle. Then you do some basic addition and subtraction w/ the weigh slips.
There is the gvwr (gross vehicle weight rating) of your tow rig, gawr of each axle and vehicle's stated towing rating. The same thing for your trailer. And, my fifth wheel hitch had a max weight rating too. All the ratings for your vehicle will be on a door or door jamb. Allowable tongue weight comes into play (a hitch rating). Oh, and don't forget load ratings for tires.
In my case, when hooked up w/ full water, propane, and stuff, I was usually at 16k lbs or 1,000lbs under truck's gvwr, but always right at or slightly over the allowable front axle rating. Never a problem at hitch or rear axle. Camper itself was alway near its gvwr.
When we were on the road we frequently saw folks towing 36' and 38' trailers w/ a basic 3/4 ton truck. And on it went. I'd shake my head and think, stay out of the mountains.
Relating this to your Bronco, process is the same. My wild ass scientific guess - one would be over an allowable axle rating or gvwr long before hitting the 3,500 lb tow rating. Is my description overkill? Perhaps, but if your towing w/ kids and wife in the car.....
Hope this helps. Take care. Contented
