It will almost certainly rub. Just get the base rims and buy Sasquatch take-offs that dozens of people on this forum will be selling.
Holy cow that’s tight, especially imagine airing down and flexing the tire into it on a rock. As light as those MTs are, I wonder how much the sidewall will take...They absolutely do.
Posted earlier is the wheel width. Also all wheels are +55mm offset, except the Sasquatch wheels which are +30.
My conclusion is a 315 tire on a +55 wheel will rub on the upper control arm.
There is a ton of discussion on this already, including CAD mock-ups of various combinations to see what probably will or won’t be a problem.
https://www.bronco6g.com/detailed-calculations-show-aftermarket-tire-size-fitments-on-bronco-trims/
That’s the Sasquatch wheel and tire all the way to the right, with the Badlands just to the left of it.
With the +55 offset the tire just clears the upper control arm. The wider 315 needs the +30 wheel to clear.
We don’t have definitive answers because no one has actually tried it yet, but I think it’s more or less settled now.
There's a great YouTube video about this. Basically all you have to do is remove the crash bars and a non-sasquatch Badlands can fit 35s.It would be nice to get the wheel size to see can it fit a 35 since it fits a 33 from the factory
If I'm not mistaken the 4WP Bronco in the video with Ryan Kenelly he states they have 37's on an 8 inch rim.IIRC, 55mm back spacing on the 1/2" wider Sasquatch wheels, that has to be for a reason. Most likely you would rub, at least on hard turns. You would also have to find someone to install the larger tires against the manufacturers recommendations (8.5" is minimum recommended wheel width), lot of places won't take the liability. You'll find someone I am sure, but I personally would not argue with the manufacturer on how to mount the tires.
