- Mike
- Apr 19, 2021
- 32
- 1,025
- 1,054
- Eatontown, Jersey
- 2dr 2.3 Manual
- Badlands
- Banned
- #76
so let it sit and warm up basically.I stand by my diagnostic hypothosis; it is a fueling issue at low RPM, high load and cold oil temps (the variable valve timing is too quick to react when the oil is cold and has a higher viscosity, slow to move the cam phasers), the high fuel demand and low RPM relatively speaking is very hard to get metered properly with a DIT only engine. I believe it is not the clutch, but the engine surging due to slightly off fueling and cam position over what it normal. If it goes away under heavier throttle or less load (level or downhill), or when the oil is over 160F, then I would feel very confident in my hypothosis.
I think it is the nature of the beast when cold started.
Might as well start it up and run back in for coffee or something as it warms up, or just double check your emails and stuff
