Tarheel_Wes
Wesley
FJ
@cwhite
Can confirm, I did this (had some leftover)...Although with the 2 door there wasn't much real estate. On the two doors, there is some exposed metal on the interior that I didn't cover...and I also didn't cover a large portion of the inside middle (where the vapor barrier covers the access point for the interior of the door).
I wanted to make sure should anyone need access to the window mechanism that they wouldn't spend half an hour to remove it. I'm not honestly sure if it made enough of a difference, but the top certainly did.
OP, can you elaborate a little on what you did with the doors? Like what exactly did you remove to gain access? Thanks
grayshadow
Charles
Humble, Texas
Total cost? Before ford offered free headliner I planned on going with the hothead headliner they had been planning to release, but honestly I think it's crazy to have turned down the free headliner.
I have been in communication with Hot Heads and itā€™s going to be a while before they have anything to release since they do not have their Bronco, I even offered them mine but itā€™s the wrong time of year for me to head to Boise, Idaho. I think the OP did you good job on his for the amount he has in it.
BTW, I elected to not have Ford install the cheap headliner they offer. Itā€™s not worth it, even free. Enjoy removing yours.
porjos
porjos
Joey
Pennsylvania
The interior door panels were pretty easy to remove.
1) Pry off the screw covers where the door handle is - I used plastic trim tools to avoid scratching the plastic, but a paint scraper will work as well if you're careful.
2) Remove the bolts, there are 3 on the bottom as well.
3) Use the trim remover tool to carefully pop out all the plastic tabs on the edges. They can break pretty easily if you apply too much pressure, so I popped each one out individually. Just stuck the tool right under the plastic and provided some pressure.
4) Unhook the wires for the door latch (pull outwards), if I remember correctly I think there's only one wire harness for the door lock.
5) Youre golden!
Tarheel_Wes
Wesley
FJ
5) Youre golden!
cool thanks
SuperDave150
Albuquerque, NM
Ford F-150, Ford Edge
Exactly. Removed the door panels, and the Dynamat attaches to the inside of the outer door skin. There are a couple different companies offering this product right now.
Right. Iā€™ve done this on my vehicles. Dynamat (tar-like sheets) applied to metal panels, including outer door skins & floors. Dynapad (foam) applied to inside of plastic interior panels or even over vapor barrier. It helps, but it canā€˜t transform a Model-T into a Lincoln.
https://www.dynamat.com/applications-industries/automotive-and-transportation/
grayshadow
Charles
Humble, Texas
After finding out the Ford NVH headliner is essentially $480 carpet, I decided to make my own headliner. For $260 I got:
* Dynamat mats (67 Mil thick - butyl rubber with aluminum backing, self-adhesive)
* 1/8 thick Dynaliner closed/open cell foam (self-adhesive)
* Some charcoal grey indoor/outdoor carpet
Here's the finished driver's side, in comparison to the bare MIC on the passenger side:
It was relatively simple:
Step 1: Clean and prep surface
Step 2: Apply sound deadener wherever it wasn't obstructing the latches or the weather stripping where it's seated on the vehicle.
Step 3: Apply closed/open cell foam to the recessed parts of the top for increased sound deadening/insultation.
Step 4: Measure and cut some carpet, I used a combination of Gorilla spray glue and well-placed VHB/3M strips.
Result: The sound improved greatly, and that's what I was looking for - still noisier than a Prius of course, but night and day compared to the bare MIC.
Thanks for your write up, it now has my creative juices flowing. I may not wait on Hot Heads headliner any longer. I checked my local fabric store online and they have a Ripstop material and a Marine Grade Vinyl. Iā€™m going tomorrow to check out the different materials.
grayshadow
Charles
Humble, Texas
So you opted out of the free headliner, and then added tacky carpet to the panels anyways?
Ok, I was able to do a little test for you today. Friend has a Badlands two door with free headliner from Ford. I have a Black Diamond two door with no headliner. Pics below so you can see that both vehicles are similar in options however, mine does have an added platform on top. His is the Cyber Orange and mine is Cactus Gray.
On the way to his house I was on the freeway cruising in my Black Diamond at 71mph, I activated the noise app on my smartwatch and it showed 73db.
We went for a ride in his Badlands with mid package cruising at 61mph, I activated the noise app and it showed 70db.
There it is, a real live test with two very similar models. Oh, and btw, we also tested a base model four door with a soft top at 61mph and it cranked up to 76db on the noise app.
Ford Bronco DIY Headliner using Dynamat and Dynaliner 8FDBE024-4E35-4EE9-976B-AA53C9F24EB3
Ford Bronco DIY Headliner using Dynamat and Dynaliner ECFE8979-4D11-450C-B975-ECC28736B706
SuperDave150
Albuquerque, NM
<< ā€¦ on the freeway cruising in my Black Diamond at 71mph, I activated the noise app on my smartwatch and it showed 73db.
We went for a ride in his Badlands with mid package cruising at 61mph, I activated the noise app and it showed 70db. ā€¦ >>
Hey wait a doggone minute here. Tests were at different speeds. Much different speeds. THEREFORE THE DATA IS INVALID BECAUSE YOU CHANGED MORE THAN ONE VARIABLE DURING YOUR TEST PROCEDURE.
Since weā€™re all friends here could you run the test again - this time on the exact same highway at the exact same speed, and you sitting in the same seating location??? Please?!?
grayshadow
Charles
Humble, Texas
If you canā€™t use the data then itā€™s probably not relevant to you.
NVCowboy
William
Henderson, NV
The canned adhesive (3M) works well. You just have to let it set up before you apply. Then reactive with a hair dryer or heat gun.
My plan for this is similar. Iā€™m going to use dynamat first, then spray bed liner over top of the dynamat to seal it in. Should add less weight and be a little quicker of a job.
I would worry about the Bed liner not absorbing as much sound as carpet. I could be wrong.
Bronc-itis
E
South Florida
Q50 (bronco soon)
Dynamat is for the reduction. The bed liner just protects the surface of the mat and seals it in.
NVCowboy
William
Henderson, NV
I can see that. I was just thinking of the difference of a room with tile and a room with carpet.
Tarheel_Wes
Wesley
FJ
Had been following this thread, and wondered if you got your rig and ended up doing this? I took delivery last week, I have the MIC with sound deadening, but I'd like to try to make it quieter.
AK007
Washington DC
Awaiting my Bronco
I was looking into some options and I'm waiting to see what Hothead headliners produce as well as I wait for my Bronco and came across this:
https://soundskinsglobal.com/produc...DYuNivZZENLXq38WUFOUUeJqeSWbsa1IaAoH2EALw_wcB
Is it really worth installing sound dampening in the floors, especially if I have Vinyl flooring? I wasnt planning on it, and is the vinyl glued to the floor? I concerned more with the hard top.
joeramirez
New Mexico
Ram Truck
@porjos How is your custom headliner holding up? Did you remove the small carpeted pieces ford installed under the latches or did you go over them?
Ford Bronco DIY Headliner using Dynamat and Dynaliner A6594E57-83CB-4C97-AF44-E026D1B65E84
