DIY Transmission Skid
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
We all know Ford was dumb for giving the Bronco skids over everything but the transmission. Worst part is, it’s right behind the tires and right where they drop off a rock you put the trans in danger. So I made a small aluminum bashed plate. I don’t full on rock crawl but do get in some spots that I could hang up here.
I make these brackets. Long one goes to the cross member bolts. The front ones go to the back of the sway bar skid. Only holes I had to drill were for the front two mounts.
Ford Bronco DIY Transmission Skid 649FA5C2-C36E-40DA-A316-653E061A801A
Had to make a few bends to match the shape of the sway bar skid plate.
Ford Bronco DIY Transmission Skid 88CFDCDB-1E87-4246-9E8F-CC080C64619E
Ford Bronco DIY Transmission Skid 5CA2C370-15D9-420F-846F-CC12A39EEF8C
Here are the mounts all bolted up.
Ford Bronco DIY Transmission Skid EFEB78E9-1653-4643-AB33-E3B1BAFC55C1
Ford Bronco DIY Transmission Skid 3E9DFF69-0829-412A-9864-FA4C328C2159
Ford Bronco DIY Transmission Skid 1F906DD2-63D7-4F77-8004-38E442DCA97E
I used a piece of 1/4 aluminum scrap. It already had a bunch of holes drilled in it, so I think that will help with air flow. I kinda worried about trapping heat, but this shouldn’t.
Ford Bronco DIY Transmission Skid 81704EC1-9C8B-4325-937D-12B3178F4315
Ford Bronco DIY Transmission Skid 480F5EA4-E84F-4D88-A3D7-1BF3E72002EE
Ford Bronco DIY Transmission Skid 1F8EE2FE-9318-40C2-84B6-A7BE3B95A293
I now feel like my transmission and the exhaust pipe have some protection. Plus there isn’t a huge hole to get hung up on a rock. I built the whole thing with scraps and some stainless hardware. Have about $10 into the build. Even if you had to buy everything, this could be easily built for less than $100.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Seriously! You could make some bucks selling this stuff! Once my Bronco comes in I'm searching for something like this.
BottleShark
BottleShark
TJ
East Texas
Thanks, I just don’t have a way produce stuff. Making them one at a time would take for ever. But this is why I did the write up. Maybe they will help others with the idea. And show people that stuff can be done affordable.
dgorsett
colorado
F250, Mustang, Explorer
Nice. I've been thinking of something similar. Mine does not have sway bar disco, I would mount angle to upper sway bar mount bolts with flange up, run skid to the rear, angle down ahead of the crossover pipe, flatten and bolt to bottom of crossmember to maximize clearance.
BottleShark
BottleShark
TJ
East Texas
I was thinking about getting some domed Allen bolts but the factory bolts stick down 🤷‍♂️
goatman2
Richard
Bakersfield
gandgautorepair.com
F450, Jeep XJ, Porsche 911, 2dr Badlands
We've had bad luck with Allen bolts on the bottom of Jeeps. When the rocks scrape over them they get nearly impossible to remove. FYI
goatman2
Richard
Bakersfield
gandgautorepair.com
Nice idea. I just had mine on the rack this afternoon putting some new wheels on it and I saw that the trans pan is plastic and exposed. That's worrisome. I like your solution. (y)
BottleShark
BottleShark
TJ
East Texas
Thanks, maybe I’ll just leave them as is.
BottleShark
BottleShark
TJ
East Texas
Such an oversight from Ford. Makes me wonder what else they missed in design……
BottleShark
BottleShark
TJ
East Texas
Does the Raptor have this area missing a skid plate?
Donkeygyrl
Sheri
San Francisco
Bronco on order
Nice work add some washers under those bolt and your good
BottleShark
BottleShark
TJ
East Texas
Yeah, I was going to replace with low profile bolts, but as others have pointed out, not the best idea.
