Don't remove your Sas option if you plan to upgrade bigger tire
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
The gear ratios confuse me a bit. Anyone know , apologies if it has been answered, why they are coming with 4.7s? The raptors only come with 4.10s even with the new 37” package.
I have an 18 raptor, my impression is that its the same trans. I realize raptor has significantly more power, but the rpms on the 2.7 have to be much higher.
higher ratio makes sense in bronco as my raptor cant hold freeway speed in a headwind without downshift. Rpms too low.
Anyways i know this isnt a raptor page but curious on the logic
This topic has been kicked a lot and there are some good threads in the Transmission/axle/gear forum. Lots of bad info too.
First rule is don’t judge adequate gears for one vehicle based on what a completely different vehicle has. There is no relevance to what a Jeep/Toyota/f150 etc has to proper Bronco gears. Different motors, transmission, weight, etc. Even if they use the same transmission it can have a different gear set for different applications.
The factory almost always goes on the high side to improve highway economy, plus most people are fine with poor performance. Very few of us actually want and appreciate a lower geared diff. I want to pull stumps, not hit the rev limiter, in my 4WD anyway.
I plan to put 4.88s or lower in at some point. Lower is almost always better in 4WDs. Besides, I’ve had my years of driving the Autobahn and don’t care what top end is like in the Bronco. It will do most of it’s work under 35mph.
BroncoPVC
Paul
Seattle
2021 Bronco Badlands,Sas, 4dr, Soft Top, Rapid Red
This is the BEST thread I've ever read! We need more of this!
OP keep the good information and thoughts coming. But just to be clear, it is okay to put bigger wheels and tires on a Non-Sas, right?
lawcdav1
Lawrence
Georgia
Any gear ratio advice for someone looking to put 20inch wheels on the Bronco
Mdeamon
Hyundai tucson
Even if you just go to the mall sometime you need bigger tires
lawcdav1
Lawrence
Georgia
I’ve got 17inch wheels on my 4Runner that are going on the Bronco
Mdeamon
Hyundai tucson
If you do offroading small the rim
Is better when you air down you need a tall side wall and also smaller the rim keep you to avoid hitting rock on your rim😁 as you mention earlier 20inch rim only for the mall but 17 is ok for offroading
Lakelife36
Ben
Interior of BC
Wow.... 3 pages!
Not even going to finish pg 1 ... lol
I thought the same when I scrolled down and saw four pages! Four!?! I must be feeling especially masochistic today to have sat through the whole thing so far. At first I thought this must not be the thread for me since I have half a clue that the only series that come standard with 3.73s are the four-door base and the two OBXs, but somehow I kept reading.
Lakelife36
Ben
Interior of BC
JPG
Montreal, Qc, Canada
Bronco Badlands
I will not recommend to remove the option of sasquash to get your Bronco sooner if you plan to upgrade for bigger tire down the road
Watch the video below before make your decision
The bronco come standard with 3.7 gear ratio i think .....
Depens the option you choose you will have better ratio for
The sasquash gear ratio is 4.7 and it design to support 35 inch tire this is very inportant when you do offroading
Down the road upgrating tire size can be costly if done correctly see the second video to have a idea what ot look like to regear to the proper ratio
EVEN if it was 3.7 gears it would be fine, i've been running my FJ Cruiser on 35s for 6 years on 3.73 gears, yeah it's not the best mpg wise, but does fine in trail. No need to panic...
Mdeamon
Hyundai tucson
What this video....
He exain why.....
Might not be a big issue in short term
Depend also what king of trail you do...
Also if you have a manuel you have more control of yohr shifting rpm....but regarless in long run it bad for your mechanic with bigger tire and not regearing.... last thing yiu want in couple year is premature mechanicd failure in the middle of no where
You will fine out the petty saving of the have proper gear ......
