Doors off issues -- airbag lights, door ajar warning, no key detected warnings
Stick355
2004 Mach 1, 2020 Explorer ST, 2021 Ranger Tremor
Weather finally got nice in the NE today so decided to take the top/doors off this morning. Been driving prior to today with zero issues. Now I have airbag lights, door ajar warning (2dr) and no key detected warnings. I can’t keep driving it and having it double honk 3-4 times at a red light, I’m gonna piss someone off 🤣. This is the first time I’ve had the doors off since I received some sort of OTA update a week-ish ago. Anyone else see this?
Combustion_King
Derek
MA
Yes
weird. i haven't had the doors off in a few weeks. however if you put them back on does it all go away?
Austin Bronco
Austin Texas
Triumph Street Scrambler
Def weird. I had the doors off about 3 weeks ago and got the normal warnings ( not airbag, but electrical disconnected). Allegedly there is a spot in the bottom of the center console to put your key if the battery is out/ truck is not recognizing it. GL
Stick355
Stick355
I have not put it all back together, I might this evening.
Stick355
Stick355
If I put the key in the little storage compartment in front of the shifter, it won’t start, pick them up and hold them, works fine. Throw them back and works fine, then get to a red light, starts honking. Does this with both keys. I’m assuming the airbag is due to the door ajar issue.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
The secret key spot is in the bottom of the center console. Not the small console in front of the shifter.
1st 75th ranger
jeffrey
nj
yeah iv had all the above no fob i just pick up my key lock un lock and im good for awhile
hook yeah only once in awhile dummy lights yeah but i just drive on and no problems
i havnt found a fix and today my bronco is naked again
AZMikeL
AZ
2022 Bronco Badlands 4dr, 2016 BMW 435i
Try a little sand paper between the bar and the 2 pins it's supposed to short out. I had door ajar issues and fixed it in about 60 seconds by cleaning those off in order to make sure that little bar is making contact with those 2 pins.
