Engine Break-in for 2.7 L Engine
Regulator Johnson
2008 FJ Cruiser
Does anyone know what mileage Ford suggests should be reached before you do full throttle acceleration and sustained freeway driving at the same rpm/speed.? What is the engine break-in mileage for the 2.7 L engine?
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Hot Pepper Diamond
Justin
Knoxville, TN
Bronco Black Diamond 4 door
What is considered high speed? I’ll have to drive mo while 3 hours once I get it… I assume high speeds means like 90+?
tyrobronco
CC
Central Florida
2021 Bronco,2017 Ford Fusion Energi
"High speeds" is kinda irrelevant, isn't it? I think it means high engine speeds - as in high RPMs.
My Bronco is at 70 MPH with around 2400 RPMs.
I kept mine under 2000 RPMs for the first 500 and then under 2500 for the next 1000 miles. Once I crossed the 1500 mile mark, I floored it onto off-ramps to make sure she could take it. She could.
I was definitely more cautious than some. I definitely wouldn't shoot for redline in the first 1000 for sure.
Marsalad
New York
2021 Bronco Big Bend
I paid for all the numbers on the tachometer and I intend to use them all!
Same goes for the speedo…
Oops, forgot I was on the Bronco forum and not the Mustang one.
myrealname123
Trent
Monterey, CA
'25 Bronco Badlands
The correct mileage is whatever is on it when you drive it off the lot.
edgeflyer
2013 FX4
200 easy miles, then let her eat.
330SMG
Dennis
Hurricane Alley
16 F150 ,89 325i and 72 Dodge Charger SE
I always break them in like I want them to run. Hard and fast from day 1. Roller cams and rockers. Just need to seat the rings. Always change oil at 1000 miles.
Firefight911
Phil
Simpsonville, South Carolina
2022 Ford Bronco 4-door Wildtrak, Eruption Green
