Factory vs Yakima Roof Rails? I'm Confused...
CDN Jen
Jennifer
Bronco Sport, 2021 Mustang GT Premium Convertible
So it looks like we can add factory roof rails and crossbars for $365 (first pic below) and then we have the option of getting Yakima crossbars for an additional $559 (second pic below).
Ford Bronco Factory vs Yakima Roof Rails? I'm Confused... factory crossbars
Ford Bronco Factory vs Yakima Roof Rails? I'm Confused... Yakima crossbars
That's almost $1000 for a roof rail system. Are the Yakima crossbars THAT much better? I have Yakima bars on my current escape but I don't have any experience with factory bars.
Will the factory crossbars not work with my current Yakima skybox? I do haul a lot of stuff on my rack (skybox, multiple kayaks, etc.). Am I better off upgrading to the Yakima crossbars or am I just paying for a name?
Any advice is appreciated.
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
I'd like to know to. I figured it was a B&P bug and the Yakima rack was $559 because B&P forces you to check both boxes off which is strange.
Edelfin
Emmanuel
TEXAS
Yakima racks & accessories are not necessarily universal. They CAN definetly fit a lot of factory racks. I can only assume the official expensive rack will mean you can use all of the brand products seamlessly and with the lifetime warranty. The second pic also doesn't really look like the Yakima rack and just a second photo of the factory rack. Maybe another B&P bug?
Atomicdog
Eddie
Philadelphia
Agreed, those 2 pics look like the same exact rack.
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
SimpleMan
Tampa
Elantra
Price wise, the Yakima crossbars on their website (https://yakima.com/collections/crossbars) go from $105 to $249. So the $559 that Ford is charging for the Yakima crossbars is definitely not worth it unless it is some new crossbar with higher end materials/capabilities... I doubt that though.
The only benefit is that it is installed for you and is covered under the warranty so if that is worth the difference then it is the crossbar for you.
If you want the Yakima crossbar I would just order it through the Yakima website or another retailer. Although then you'd have to make sure that it is compatible with the Roof Rail so there's that
RedHotFuzz
2022 Bronco Black Diamond 4D
The Yakima Skybox mounting system should work with nearly any factory (or aftermarket) crossbar. It's just a hook clamp-style system. I had one for years on my Honda Pilot with the factory roof rails.
