Great. I may skip that step. I also changed the length to 70 mm. Seems the 90 mm were a little to long based on the thread depth using their bolt with the 2 x 1/2 in spacers they provide. Did you cut the 90 mm bolts?
I used the two 1/2 inch spacers that come with the kit in conjunction with a 1 inch rubber Timbren spacer for a total of 2 inches on each side, hence the reason for using the 90mm.Great. I may skip that step. I also changed the length to 70 mm. Seems the 90 mm were a little to long based on the thread depth using their bolt with the 2 x 1/2 in spacers they provide. Did you cut the 90 mm bolts?
