Flat Tow failure
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
Just found this. Read carefully and you will note it calls for towed vehicle to be in park! This is the code they are using to deny warranty! What is it Ford? Owners manual says leave in neutral. This says park so parking pall is engaged.
No wonder they won't give people any information when they deny warranty.
CoolContractor
Fred
Come on Ford, what a bunch of crap.
dgorsett
colorado
F250, Mustang, Explorer
Interesting. And it would work to tow in Neutral tow transmission in park (my Jeep was this way), BUT the procedure to disengage Neutral tow involves applying brake and putting in Park, which would happen when the Auxiliary brake system engaged, so not a good idea.
Now to disengage requires Accessory Mode to be on, but still sounds dangerous.
Fordified1
Bob
Mid South Texas
I believe the procedure to flat tow an F150 Raptor says transmission in park. This is also a 10speed with Advanced transfer case but the larger 10-speed transmission. I read about at least two Raptors burning to the ground and at least one taking the motorhome with it when flat towing. I can imagine the parking pawl making an incredible amount of heat should the transfer case shift back into gear while towing.
Fordified1
Bob
Mid South Texas
Well I just test fit the Bronco and towbar behind the MH, and for curiosity sake tried to put it in tow mode without looking up the procedure. It will NOT go into tow mode and give the “Neutral Tow Enabled” indication without following the procedure exactly. So I don’t know where Ford gets off blaming the customers for transmission failures caused by towing. NO ONE in their right mind is flat towing without the dash indicating “tow enabled”.
Ford Bronco Flat Tow failure IMG_0395
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
Curious, whats that limit 30 sign on the screen? I've never seen that on my screen.
Fordified1
Bob
Mid South Texas
I wondered the same thing…. Speed limit of the street I’m on. GPS shows the speed limits on my cluster display.
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
What variation Bronco do you own? I have a Squach and never saw that before.
BTW my wife and I fell in love with your state last winter. People we met were great, so much to do. We hit Texarkana, Fort Worth, Waco, Victoria, Rockport, Fort Davis, Amarillo allong with many other locations. First snowbird vacation for us.
Fordified1
Bob
Mid South Texas
‘24 Black Diamond mid package non-SAS. There was a thread about it somewhere. I had forgotten it was even there except the pic I took reminded me lol.
Thanks, we moved back to TX after 15 years in another state because most of people are so friendly and down to earth. I hope you got to see some of the hill country.
Bob
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
We stayed at Inks Lake state park during the big ice storm that did so much damage in Austin. I think there was only 5 other rigs there, everyone else bugged out before it hit, even the park rangers! I believe that is considered hill country. We explored the entire area and had a blast!
Duane
Dirtrider
Bruce
St. Louis
Honda Ridgeline, Super-C Motorhome
I have the Manual Transmission with 4A. Although I believe it to be splash lubricated and shouldn't have an issue, it could also be turning in flat tow mode just due to the residual friction in the transfer case. I've towed it about 5000 miles with no issues. I haven't seen any reports of MT damage while flat towing (other than the synchro problem addressed in the TCB, mine were replaced but that issue was discovered prior to ever towing but fixed later). I still wonder if perhaps there might be less wear on the MT if it were left in gear while flat towing. The manual says to put the MT in neutral while flat towing. Any indication that this instruction should be or has been changed?
73Corvetteman
Duane
Hudsonville, Mi
2023 bronco
This is for the automatic 10 speed. I don't believe it applies to the manual transmission.
Fordified1
Bob
Mid South Texas
On my way to the beach Friday morning. No problems so far.
Ford Bronco Flat Tow failure IMG_0419
Ford Bronco Flat Tow failure image000000
Bsenecal
Vermont
'19 Ranger crew cab, '17 Fusion sport, '68 Mustang
Nice American Coach, and Bronco, we just got a 2022 American Dream looking forward to finishing up the flat tow setup on our Bronco.
Hope to see you out there.
